Up to 20% off select tools
Surface Studio M.2 SSD Replacement
Views: 15K
View statistics:
Past 24 Hours:
8
Past 7 Days:
40
Past 30 Days:
179
All Time:
14,835
Comments: 23
2 comments on steps, 21 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Do you want a bigger SSD or perhaps a faster PCIe NVMe SSD? Follow this guide to replace your SSD.
(Note: Surface Studio with Intel Core i5 comes with SATA III SSD while Surface Studio with Intel Core i7 comes with PCIe NVMe SSD.)
    1. Surface Studio M.2 SSD Replacement, M.2 SSD: step 1, image 1 of 3 Surface Studio M.2 SSD Replacement, M.2 SSD: step 1, image 2 of 3 Surface Studio M.2 SSD Replacement, M.2 SSD: step 1, image 3 of 3
      • Lay the Surface face down on a padded surface
      • Be careful not to scratch the screen when laying it face down
      • Remove the four rubber feet at each corner concealing the Torx screws
      • Remove the four Torx screws under the rubber feet.
      • Two screws on the upper corners are longer than two screws on the lower corners.
      • Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
      Ask FixBot
    2. Surface Studio M.2 SSD Replacement: step 2, image 1 of 2 Surface Studio M.2 SSD Replacement: step 2, image 2 of 2
      • Remove five torx screws holding the two fans to the midframe
      • Remove the two fans
      • The fan connectors are behind the midframe and not yet accessible. Let the fans hang loosely until you can access the connectors.
      • Four large torx screws and four small torx screws hold the midframe to the upper frame.
      • Remove four large torx screws holding the midframe
      • Remove four small torx screws holding the midframe
      Ask FixBot
    3. Surface Studio M.2 SSD Replacement: step 3, image 1 of 1
      • Slowly remove the midframe
      • Be careful, the speaker on the midframe is still attached to the motherboard
      • Detach the connectors for the two fans and the speaker
      Ask FixBot
    4. Surface Studio M.2 SSD Replacement: step 4, image 1 of 2 Surface Studio M.2 SSD Replacement: step 4, image 2 of 2
      • With the midframe removed, the M.2 SSD is now accessible
      • Remove a torx screw holding the M.2 holding the SSD to the motherboard
      • Pull the SSD straight back
      • Do not pull the SSD upward or risk damaging the M.2 socket
      • The M.2 socket is compatible with most SATA III, PCIe ACHI, and PCIe NVMe in the M.2 2280 form factor
      Ask FixBot
8 other people completed this guide.
Author
with
The Raptor
6,415 Reputation
6 Guides authored
21 Guide Comments
I know that one of the very first questions would be: Does the M.2 slot supports PCIe NVMe ?
The answer is: Yes it does.
The Raptor - Reply Share
But it does not mean that you can get the drive to run in NVMe model.
There does not appear to be a setting to enable NVMe model for the drive.
John - Reply Share
Does it support bootable NVMe?
Mark Smith - Reply Share
@msmith4099 @theofficemaven
Sure. When installing Windows, choose to install Windows to "Drive 1" instead of "Drive 0"
Is there any raid options that need to be configured?
Past 24 Hours: 8
Past 7 Days: 40
Past 30 Days: 179
All Time: 14,835
