Surface Studio 2.5" Hard Drive or Fans Replacement
    1. Surface Studio 2.5" Hard Drive or Fans Replacement, 2.5" Hard Drive and/or Cooling Fans (2): step 1, image 1 of 3 Surface Studio 2.5" Hard Drive or Fans Replacement, 2.5" Hard Drive and/or Cooling Fans (2): step 1, image 2 of 3 Surface Studio 2.5" Hard Drive or Fans Replacement, 2.5" Hard Drive and/or Cooling Fans (2): step 1, image 3 of 3
      • Lay the Surface face down on a padded surface
      • Be careful not to scratch the screen when laying it face down
      • Remove the four rubber feet at each corner concealing the Torx screws
      • Remove the four Torx screws under the rubber feet.
      • Two screws on the upper corners are longer than two screws on the lower corners.
      • Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
      Ask FixBot
    2. Surface Studio 2.5" Hard Drive or Fans Replacement: step 2, image 1 of 2 Surface Studio 2.5" Hard Drive or Fans Replacement: step 2, image 2 of 2
      • Remove five torx screws holding the two fans to the midframe
      • Remove the two fans
      • The fan connectors are behind the midframe and not yet accessible. Let the fans hang loosely until you can access the connectors.
      • Four large torx screws and four small torx screws hold the midframe to the upper frame.
      • Remove four large torx screws holding the midframe
      • Remove four small torx screws holding the midframe. Note: The 4th blue circle is missing in the picture and is above the far right green circle. In line with the second red circle and below the GPU heat sink.
      Ask FixBot
    3. Surface Studio 2.5" Hard Drive or Fans Replacement: step 3, image 1 of 1
      • Slowly remove the midframe
      • Be careful: the speaker on the midframe is still attached to the motherboard
      • Detach the connectors for the two fans and the speaker
      Ask FixBot
    4. Surface Studio 2.5" Hard Drive or Fans Replacement: step 4, image 1 of 3 Surface Studio 2.5" Hard Drive or Fans Replacement: step 4, image 2 of 3 Surface Studio 2.5" Hard Drive or Fans Replacement: step 4, image 3 of 3
      • With the midframe removed, it is also possible to replace the M.2 SSD during this step
      • The hard drive is underneath the heatsink so the heatsink must be removed
      • Fully loosen (they don't come out) the four spring loaded torx screws labeled 1 to 4;
      • Remove three torx screw labeled 5 to 7
      • Remove 5mm hex mounting post
      • Use a spudger to remove the heatsink assembly from the motherboard
      Ask FixBot
    5. Surface Studio 2.5" Hard Drive or Fans Replacement: step 5, image 1 of 3 Surface Studio 2.5" Hard Drive or Fans Replacement: step 5, image 2 of 3 Surface Studio 2.5" Hard Drive or Fans Replacement: step 5, image 3 of 3
      • Remove three torx screws holding the hard drive brackets
      • Remove the hard drive and disconnect the SATA/SATA power cable
      • Remove four torx screws holding the hard drive brackets to the hard drive
      • On reassembly, be sure to clean the CPU and GPU and heat sink and reapply thermal compound to the CPU and GPU
      Ask FixBot
18 other people completed this guide.
The Raptor
6,358 Reputation
6 Guides authored
15 Guide Comments
Thank you for this step by step guide to replace the "Hard Drive" Here are a few measures that I took before drive replacement:
1) have to turn off drive encryption
2) I cloned the drive to the new SSD drive (I used Samsung 850 PRO 1TB) using Acronis True Image
3) Replaced the drive followed your instructions.
4) Turned ON the Surface Studio and success! no issues and better performance.
Carlos Idrobo - Reply Share
Does changing to a SSD drive cut down on the fan noise?
vanstar7 - Reply Share
vanstar7 - January 15
No, fan noise level does not change, the heat that is been produced comes mostly from the processor.
Did you only change the m.2 drive? Or both drives?
hctrumpet - Reply Share
I upgraded to to a SATA SSD 2TB and a M.2 NVMe SSD 1TB and wrote my experience here:
https://blogs.msdn.microsoft.com/cesarde...
Cesar De la Torre - Reply Share
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 121
All Time: 20,435
