Surface Laptop Studio Surflink Port Replacement
  1. Surface Laptop Studio Surflink Port Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
    Ask FixBot
  2. Surface Laptop Studio Surflink Port Replacement: step 2, image 1 of 2 Surface Laptop Studio Surflink Port Replacement: step 2, image 2 of 2
    • Use a hair dryer to lightly heat the rubber feet to soften the adhesive securing them to the case.
    • Remove the two rubber feet on the lower case with an opening tool.
    • If you intend to reuse the rubber feet, take care not to warp, stretch, or tear them during removal.
    Ask FixBot
  3. Surface Laptop Studio Surflink Port Replacement: step 3, image 1 of 1
    • Remove the two screws with a T3 Torx screwdriver.
    Ask FixBot
  4. Surface Laptop Studio Surflink Port Replacement: step 4, image 1 of 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
    Ask FixBot
  5. Surface Laptop Studio Surflink Port Replacement: step 5, image 1 of 2 Surface Laptop Studio Surflink Port Replacement: step 5, image 2 of 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
    Ask FixBot
  6. Surface Laptop Studio Surflink Port Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 1 of 2 Surface Laptop Studio Surflink Port Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 2 of 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
    Ask FixBot
  7. Surface Laptop Studio Surflink Port Replacement, Surflink Port: step 7, image 1 of 3 Surface Laptop Studio Surflink Port Replacement, Surflink Port: step 7, image 2 of 3 Surface Laptop Studio Surflink Port Replacement, Surflink Port: step 7, image 3 of 3
    • Remove the left I/O bracket by unscrewing the the three M1109237 screws with your T3 Torx Screwdriver.
    Ask FixBot
  8. Surface Laptop Studio Surflink Port Replacement: step 8, image 1 of 2 Surface Laptop Studio Surflink Port Replacement: step 8, image 2 of 2
    • Remove the two M1149393 screws that secure the ribbon cable with your T3 Torx screwdriver.
    Ask FixBot
  9. Surface Laptop Studio Surflink Port Replacement: step 9, image 1 of 1
    • Lightly disconnect the flat-top connector by lifting it straight up with an opening tool.
    Ask FixBot
  10. Surface Laptop Studio Surflink Port Replacement: step 10, image 1 of 1
    • Remove the two M1149393 screws that secure the Surflink port with your T3 Torx screwdriver.
    Ask FixBot
  11. Surface Laptop Studio Surflink Port Replacement: step 11, image 1 of 1
    Buy
    • Lift the surflink port out and up with your tweezers.
    Ask FixBot
1 Guide Comment
Dont even bother reading this unless you already have aquired the surflink port. They are basically impossible to get the parts through ifixit and microsoft. in europe at least.
Robin Trapman - Reply Share
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 65
All Time: 2,118
