Up to 20% off select tools
Surface Laptop Studio SSD Replacement
Views: 16K
View statistics:
Past 24 Hours:
11
Past 7 Days:
67
Past 30 Days:
320
All Time:
16,426
Comments: 11
6 comments on steps, 5 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 40 minutes
Difficulty: Moderate
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
  • Surface Laptop Studio SSD - Genuine
Tools
Introduction
Go to step 1 ↓
This is a guide to replace the SSD in a Microsoft Surface Laptop Studio. You may need to replace the SSD if your computer is slower opening or using files. A bad SSD may also cause files to disappear. This is a very simple guide that only requires a few tools. It should only take 15-20 minutes.
    1. Surface Laptop Studio SSD Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
      Ask FixBot
    2. Surface Laptop Studio SSD Replacement: step 2, image 1 of 2 Surface Laptop Studio SSD Replacement: step 2, image 2 of 2
      • Use a hair dryer to lightly heat the rubber feet to soften the adhesive securing them to the case.
      • Remove the two rubber feet on the lower case with an opening tool.
      • If you intend to reuse the rubber feet, take care not to warp, stretch, or tear them during removal.
      Ask FixBot
    3. Surface Laptop Studio SSD Replacement: step 3, image 1 of 1
      • Remove the two screws with a T3 Torx screwdriver.
      Ask FixBot
    4. Surface Laptop Studio SSD Replacement: step 4, image 1 of 1
      • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
      Ask FixBot
    5. Surface Laptop Studio SSD Replacement: step 5, image 1 of 2 Surface Laptop Studio SSD Replacement: step 5, image 2 of 2
      • Lift the lower case gently and set it above the device.
      • Take care not to strain the battery cable as you move the lower case.
      Ask FixBot
    1. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 1 of 2 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 2 of 2
      • Disconnect the battery cable by lifting the pull tab until it "clicks."
      Ask FixBot
    1. Surface Laptop Studio SSD Replacement, SSD: step 7, image 1 of 1
      • After removing the devices battery, locate the SSD next to the mother board.
      Ask FixBot
    2. Surface Laptop Studio SSD Replacement: step 8, image 1 of 1
      • Remove the single 3 mm screw that secures the SSD.
      Ask FixBot
    3. Surface Laptop Studio SSD Replacement: step 9, image 1 of 1
      • Slide the SSD directly out of its socket.
      Ask FixBot
5 other people completed this guide.
Author
with
Nate Ball
756 Reputation
5 Guides authored
5 Guide Comments
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - Reply Share
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - Reply Share
Can you fit a full sized ssd or only the short ones?
Omega_o7 - Reply Share
You can fit a full-size (M.2 2280) SSD in the Suface Laptop Studio, but you won't be reusing the metal bracket that is there for the small SDD (2230 size). More info available here: https://dancharblog.wordpress.com/2021/1...
DoktorDread - Reply Share
Past 24 Hours: 11
Past 7 Days: 67
Past 30 Days: 320
All Time: 16,426
