Surface Laptop Studio Battery Replacement
Views: 18K
View statistics:
Past 24 Hours:
13
Past 7 Days:
142
Past 30 Days:
655
All Time:
17,904
Comments: 12
5 comments on steps, 7 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a guide on how to replace the battery in a Microsoft Surface Laptop Studio. You may need to replace your battery if your device is unresponsive and won't turn on after charging it, or if battery life is short. You will only need a few tools for the repair and it only takes 10-15 minutes.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Surface Laptop Studio Battery Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
      Ask FixBot
    2. Surface Laptop Studio Battery Replacement: step 2, image 1 of 2 Surface Laptop Studio Battery Replacement: step 2, image 2 of 2
      • Use a hair dryer to lightly heat the rubber feet to soften the adhesive securing them to the case.
      • Remove the two rubber feet on the lower case with an opening tool.
      • If you intend to reuse the rubber feet, take care not to warp, stretch, or tear them during removal.
      Ask FixBot
    3. Surface Laptop Studio Battery Replacement: step 3, image 1 of 1
      • Remove the two screws with a T3 Torx screwdriver.
      Ask FixBot
    4. Surface Laptop Studio Battery Replacement: step 4, image 1 of 1
      • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
      Ask FixBot
    5. Surface Laptop Studio Battery Replacement: step 5, image 1 of 2 Surface Laptop Studio Battery Replacement: step 5, image 2 of 2
      • Lift the lower case gently and set it above the device.
      • Take care not to strain the battery cable as you move the lower case.
      Ask FixBot
    1. Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 1 of 2 Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: step 6, image 2 of 2
      • Disconnect the battery cable by lifting the pull tab until it "clicks."
      Ask FixBot
    1. Surface Laptop Studio Battery Replacement, Battery: step 7, image 1 of 2 Surface Laptop Studio Battery Replacement, Battery: step 7, image 2 of 2
      • Pull the pull tabs to release the adhesive securing the battery.
      • Remove the battery.
      • You will need to reattach the new battery with adhesive.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.c
7 Guide Comments
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Omar Abouelseoud - Reply Share
Are the rubber feet re-attachable to the laptop after repairs?
Any link to buy the battery ?
Alberto Guinea (Shlenderman) - Reply Share
The what you need section should also mention Surface Laptop Studio Cosmetic Plate - Genuine, possibly as an optional part.
Ronno Das - Reply Share
Great point, Ronno! We added that to the parts list. Thanks for your comment.
Connor Bassolino - Reply Share
Past 24 Hours: 13
Past 7 Days: 142
Past 30 Days: 655
All Time: 17,904
