Introduction
The Surface Go models use a soldered-down eMMC or NVME SSD, which can be replaced if you have the necessary BGA rework skills.
Follow the steps in the screen replacement guide up until you have removed the screen
Remove two Phillips 00 screws from the battery and apply insulating tape to stop it re-connecting
Remove the 6 Phillips 00 screws from the CPU thermal plate and pry it off
Use tweezers to pry off the metal shield from the SSD, located to the left of the display connector (upside down in this image)
Remove all screws and connectors from the motherboard, then carefully lift it out
The NVME (128GB or 256GB) models use a BGA291 PCIE 3.0 SSD, which has the NAND and SSD controller on the same chip. This one is a Kioxia BG4 256GB chip
The eMMC models (64GB) use a different ball layout (BGA153)
Remove the chip using hot air rework and flux
