Surface Go 2 and 3 Battery Replacement
      • Follow the steps in the screen replacement guide up until you have removed the screen
      • Be careful not to crack the screen or damage the touchscreen cables
      Ask FixBot
    1. Surface Go 2 and 3 Battery Replacement, Disconnect the battery: step 2, image 1 of 1
      • Remove two Phillips 00 screws from the battery connecter
      • Lift up the connector and insulate it with tape, so that you don't accidentally reconnect the battery
      Ask FixBot
    2. Surface Go 2 and 3 Battery Replacement, Use adhesive remover: step 3, image 1 of 1
      • Use 99% isopropyl alcohol or Ifixit adhesive remover to soften the adhesive under the battery
      • Tilt the device to make sure the adhesive remover flows underneath the battery, and leave it for 1-3 minutes
      Ask FixBot
      • Use a plastic card or thin cutting wire to slice up the adhesive. Most of it is concentrated in the middle of each cell. Using a suction cup to pry on each cell can also help.
      Ask FixBot
      • Peel off the old adhesive tape and clean the area with more isopropyl alcohol
      • You should also remove the old screen adhesive, both on the case and on the screen itself
      Ask FixBot
      • Place new double-sided adhesive on the replacement battery, and press down to stick it in place
      • Install the screws onto the battery connector
      Ask FixBot
      • Apply new adhesive to the screen, reconnect it, and apply firm pressure to adhere it
      Ask FixBot
Finish Line
Chris P. Croutonne
1,208 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 64
Past 30 Days: 195
All Time: 313
