Tools
Introduction
Go to step 1 ↓If your Supreme Trimmer has a broken T shaper blade this guide will help you manually replace the blade at home. If your blade is broken or chipped it is unusable and a safety hazard. Your blade is what actually cuts the hair on your client so any damage should be found immediately. If you were to use it in that condition it would cut the skin of your client. When barbering a trimmer is a very important tool and must always be ready for use and instead of buying a new trimmer just use this guide to manually do it yourself and save money. In the first steps it make sure you clean any outer or inner hair which is something I highly recommend.
2 other people completed this guide.
