Supersonic SC-777BT Motherboard Replacement
  1. Supersonic SC-777BT Motherboard Replacement, Motherboard: step 1, image 1 of 2 Supersonic SC-777BT Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Pry open backing of the tablet using an iFixit opening tool.
  2. Supersonic SC-777BT Motherboard Replacement: step 2, image 1 of 2 Supersonic SC-777BT Motherboard Replacement: step 2, image 2 of 2
    • Use a PH000 screwdriver to unscrew all four motherboard screws.
  3. Supersonic SC-777BT Motherboard Replacement: step 3, image 1 of 3 Supersonic SC-777BT Motherboard Replacement: step 3, image 2 of 3 Supersonic SC-777BT Motherboard Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Unscrew the holder of the camera and gently remove using tweezers.
    • Remove the sensors using tweezers.
  4. Supersonic SC-777BT Motherboard Replacement: step 4, image 1 of 3 Supersonic SC-777BT Motherboard Replacement: step 4, image 2 of 3 Supersonic SC-777BT Motherboard Replacement: step 4, image 3 of 3
    • Detach the battery.
    • Battery is attached with adhesive; no tools needed to remove.
    • Using tweezers, lift and release the ribbon cable that was covered by the battery.
  5. Supersonic SC-777BT Motherboard Replacement: step 5, image 1 of 2 Supersonic SC-777BT Motherboard Replacement: step 5, image 2 of 2
    • Carefully remove the motherboard with your hands.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 56
All Time: 548
