Up to 20% off select tools
Supersonic Matrix SC-91MID Back Cover Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
57
All Time:
655
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
In this replacement guide, we will show you how to remove the back cover and all of the inside components of your tablet in order to replace the back cover.
    1. Supersonic Matrix SC-91MID Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • To begin, insert the plastic opening tool between the display and back cover and apply force until the back cover comes free from the device.
      Ask FixBot
    2. Supersonic Matrix SC-91MID Back Cover Replacement: step 2, image 1 of 3 Supersonic Matrix SC-91MID Back Cover Replacement: step 2, image 2 of 3 Supersonic Matrix SC-91MID Back Cover Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Carefully remove orange ribbons from the motherboard by opening the small plastic flaps and pulling with tweezers.
      • This will disconnect the front part of the tablet from the back entirely. Set it safely aside and continue
      Ask FixBot
    3. Supersonic Matrix SC-91MID Back Cover Replacement: step 3, image 1 of 2 Supersonic Matrix SC-91MID Back Cover Replacement: step 3, image 2 of 2
      • To remove the battery, use the plastic opening tool to pry one corner off of the battery and gently move the opening tool down to pull up one side of the battery.
      • The battery is glued down, so some force may be required to remove it from the back cover.
      Ask FixBot
    4. Supersonic Matrix SC-91MID Back Cover Replacement: step 4, image 1 of 2 Supersonic Matrix SC-91MID Back Cover Replacement: step 4, image 2 of 2
      • To remove the speakers, use the plastic opening tool to gently pry the speaker from the back cover, then use the tweezers to remove them fully.
      Ask FixBot
    5. Supersonic Matrix SC-91MID Back Cover Replacement: step 5, image 1 of 3 Supersonic Matrix SC-91MID Back Cover Replacement: step 5, image 2 of 3 Supersonic Matrix SC-91MID Back Cover Replacement: step 5, image 3 of 3
      • To remove the motherboard, start by unscrewing the three (3) small Phillips head screws using a 1.5 mm Phillips head (Phillips #000) screwdriver.
      • The small red washers must be kept along with the screws when reassembling the device, make sure you store them safely until reassembling.
      • The motherboard has soldered connections to the battery, speakers, and the charging indicator LED. Be careful when pulling the motherboard from the back cover because these parts will come along with it.
      Ask FixBot
Author
with
Michael Turner
121 Reputation
1 Guide authored
IUPUI, Team S1-G1, Wilson Spring 2018 Member of IUPUI, Team S1-G1, Wilson Spring 2018
IUPUI-WILSON-S18S1G1
5 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 57
All Time: 655
