Supercycle SC1800 Tire Replacement
    1. Supercycle SC1800 Tire Replacement, Tire: step 1, image 1 of 1
      • Deflate the tire by pressing the valve stem in.
      • If it's difficult to press the stem in with your hands, use a plastic wedge tool.
      Ask FixBot
    2. Supercycle SC1800 Tire Replacement: step 2, image 1 of 1
      • Once the tire is deflated, press the beading inside until it is removed from the rim.
      • If you need to replace your rim, do it now.
      Ask FixBot
    3. Supercycle SC1800 Tire Replacement: step 3, image 1 of 1
      • Slide the plastic wedge tool under the beading of the tire, and pull it outwards.
      • The tool is not required, but it makes the job easier.
      • Once the tire is removed from the rim on one side, do the same to other side.
      • Make sure not to puncture the tire tube, as you will need that for the new tire.
      Ask FixBot
    4. Supercycle SC1800 Tire Replacement: step 4, image 1 of 2 Supercycle SC1800 Tire Replacement: step 4, image 2 of 2
      • Pull out the tire tube from the tire and transfer it into the new tire.
      • Make sure the valve is facing towards the center as shown in the second picture.
      • If you must replace your tire tube, do it now.
      Ask FixBot
    5. Supercycle SC1800 Tire Replacement: step 5, image 1 of 1
      • Once the tube is in place, use a little bit of force to get the beading into the rim, making sure the valve goes through the designated hole in the rim.
      • If it starts getting difficult to push the beading with your hands, use the plastic wedge tool to finish.
      • It is important for the valve to correctly line with the valve hole first. Otherwise, you risk damaging the tire tube.
      Ask FixBot
    6. Supercycle SC1800 Tire Replacement: step 6, image 1 of 1
      • Do the same to both sides of the beading. You will need to use the plastic tool for the other side.
      Ask FixBot
    7. Supercycle SC1800 Tire Replacement: step 7, image 1 of 1
      • Re-inflate the tire.
      • It may be difficult to re-inflate due to the folds in the deflated tire tube. Be patient!
      Ask FixBot
Finish Line
2 other people completed this guide.
Firuz Khandakar
219 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 86
All Time: 1,849
