SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement
    1. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Back Cover: step 1, image 1 of 1
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: step 2, image 1 of 1
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
      Ask FixBot
    3. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: step 3, image 1 of 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: step 3, image 2 of 2
      • Lift the back cover from the body of the device to expose the internal components.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: step 4, image 1 of 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: step 4, image 2 of 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: step 4, image 3 of 3
      • Remove the Battery
      • The battery is secured to the back panel with tape and glue.
      • Peel back the tape around the battery and discard it.
      • Tear through the adhesive holding the battery by using the spudger tool.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: step 5, image 1 of 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: step 5, image 2 of 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: step 5, image 3 of 3
      • Desolder the 2 Battery Wires
      • The Battery has two wires connected to the motherboard (one black and one red).
      • If you're unfamiliar with soldering or desoldering check out this guide.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: step 6, image 1 of 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: step 6, image 2 of 2
      • Remove the two Phillips #00 screws attaching the housing of the camera to the device.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: step 7, image 1 of 1
      • With the screws removed you should easily be able to remove the camera unit.
      Ask FixBot
    3. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: step 8, image 1 of 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: step 8, image 2 of 2
      • Follow the camera unit back to the motherboard.
      • Use the spudger tool to remove the camera.
      Ask FixBot
Harris Dagha
866 Reputation
7 Guides authored
Dr Shaverz boyz Member of Dr Shaverz boyz
Community
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 54
All Time: 515
