SuperSonic Matrix Mid SC-999 Microphone Replacement
    1. SuperSonic Matrix Mid SC-999 Microphone Replacement, Back Cover: step 1, image 1 of 1
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 Microphone Replacement: step 2, image 1 of 1
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
      Ask FixBot
    3. SuperSonic Matrix Mid SC-999 Microphone Replacement: step 3, image 1 of 2 SuperSonic Matrix Mid SC-999 Microphone Replacement: step 3, image 2 of 2
      • Lift the back cover from the body of the device to expose the internal components.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 Microphone Replacement, Microphone: step 4, image 1 of 1
      • Remove the microphone from its compartment.
      • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 Microphone Replacement: step 5, image 1 of 2 SuperSonic Matrix Mid SC-999 Microphone Replacement: step 5, image 2 of 2
      • Use the soldering iron to remove the wires connected to the microphone.
      • If you're unfamiliar with soldering or desoldering, check out this guide.
      • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
      Ask FixBot
Harris Dagha
866 Reputation
7 Guides authored
Dr Shaverz boyz Member of Dr Shaverz boyz
Community
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 39
All Time: 441
