SuperSonic Matrix Mid SC-999 LCD Replacement
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Back Cover: step 1, image 1 of 1
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: step 2, image 1 of 1
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
      Ask FixBot
    3. SuperSonic Matrix Mid SC-999 LCD Replacement: step 3, image 1 of 2 SuperSonic Matrix Mid SC-999 LCD Replacement: step 3, image 2 of 2
      • Lift the back cover from the body of the device to expose the internal components.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: step 4, image 1 of 3 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: step 4, image 2 of 3 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: step 4, image 3 of 3
      • Remove the Battery
      • The battery is secured to the back panel with tape and glue.
      • Peel back the tape around the battery and discard it.
      • Tear through the adhesive holding the battery by using the spudger tool.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: step 5, image 1 of 3 SuperSonic Matrix Mid SC-999 LCD Replacement: step 5, image 2 of 3 SuperSonic Matrix Mid SC-999 LCD Replacement: step 5, image 3 of 3
      • Desolder the 2 Battery Wires
      • The Battery has two wires connected to the motherboard (one black and one red).
      • If you're unfamiliar with soldering or desoldering check out this guide.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Speaker: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the Speakers
      • Use the tweezers to remove the speakers from their compartments.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: step 7, image 1 of 2 SuperSonic Matrix Mid SC-999 LCD Replacement: step 7, image 2 of 2
      • Desolder the 4 Speaker Wires
      • These wires connect the speakers to the motherboard. They are the thinnest wires.
      • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Microphone: step 8, image 1 of 1
      • Remove the microphone from its compartment.
      • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: step 9, image 1 of 2 SuperSonic Matrix Mid SC-999 LCD Replacement: step 9, image 2 of 2
      • Use the soldering iron to remove the wires connected to the microphone.
      • If you're unfamiliar with soldering or desoldering, check out this guide.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: step 10, image 1 of 2 SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: step 10, image 2 of 2
      • Use a soldering iron to desolder the region circled in red.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: step 11, image 1 of 2 SuperSonic Matrix Mid SC-999 LCD Replacement: step 11, image 2 of 2
      • Desolder the FM antenna from the motherboard.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: step 12, image 1 of 2 SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: step 12, image 2 of 2
      • Remove the large ribbon cable from the socket that attaches it to the motherboard.
      • Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 LCD Replacement: step 13, image 1 of 2 SuperSonic Matrix Mid SC-999 LCD Replacement: step 13, image 2 of 2
      • Remove the small ribbon cable from the socket that attaches it to the motherboard.
      • Flip the dark grey latch to release the ribbon cable from the motherboard.
      Ask FixBot
    3. SuperSonic Matrix Mid SC-999 LCD Replacement: step 14, image 1 of 3 SuperSonic Matrix Mid SC-999 LCD Replacement: step 14, image 2 of 3 SuperSonic Matrix Mid SC-999 LCD Replacement: step 14, image 3 of 3
      • Remove the four Phillips #00 screws attaching the motherboard to the device.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: step 15, image 1 of 3 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: step 15, image 2 of 3 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: step 15, image 3 of 3
      • Ensure that the motherboard and all other items are off before continuing.
      • Separate the screen and back housing by gently pulling on it.
      Ask FixBot
4 other people completed this guide.
Harris Dagha
866 Reputation
7 Guides authored
Dr Shaverz boyz Member of Dr Shaverz boyz
Community
3 Members
84 Guides authored
1 Guide Comment
what is the part number & where can I get a replacement screen for the SC-8809
impaired27 - Reply Share
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 32
All Time: 1,401
