SuperSonic Matrix Mid SC-999 Battery Replacement
    1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: step 1, image 1 of 1
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 Battery Replacement: step 2, image 1 of 1
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
      Ask FixBot
    3. SuperSonic Matrix Mid SC-999 Battery Replacement: step 3, image 1 of 2 SuperSonic Matrix Mid SC-999 Battery Replacement: step 3, image 2 of 2
      • Lift the back cover from the body of the device to expose the internal components.
      Ask FixBot
    1. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: step 4, image 1 of 3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: step 4, image 2 of 3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: step 4, image 3 of 3
      • Remove the Battery
      • The battery is secured to the back panel with tape and glue.
      • Peel back the tape around the battery and discard it.
      • Tear through the adhesive holding the battery by using the spudger tool.
      Ask FixBot
    2. SuperSonic Matrix Mid SC-999 Battery Replacement: step 5, image 1 of 3 SuperSonic Matrix Mid SC-999 Battery Replacement: step 5, image 2 of 3 SuperSonic Matrix Mid SC-999 Battery Replacement: step 5, image 3 of 3
      • Desolder the 2 Battery Wires
      • The Battery has two wires connected to the motherboard (one black and one red).
      • If you're unfamiliar with soldering or desoldering check out this guide.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
      Ask FixBot
2 other people completed this guide.
Collin Ferguson
176 Reputation
1 Guide authored
Baylor, Team 6-1, Shaver Spring 2015 Member of Baylor, Team 6-1, Shaver Spring 2015
BU-SHAVER-S15S6G1
4 Members
108 Guides authored
1 Guide Comment
Link to the soldering technique guide!
Josh Lewis - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 32
All Time: 2,747
