Up to 20% off select tools
Super Nintendo Power Switch Replacement
Views: 27K
View statistics:
Past 24 Hours:
8
Past 7 Days:
43
Past 30 Days:
179
All Time:
27,353
Comments: 8
6 comments on steps, 2 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 19
19 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the power switch connected to the motherboard. Steps can be followed in reverse to install a new power switch.
    1. Super Nintendo Power Switch Replacement, Outer Case: step 1, image 1 of 1
      • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
      Ask FixBot
    2. Super Nintendo Power Switch Replacement: step 2, image 1 of 3 Super Nintendo Power Switch Replacement: step 2, image 2 of 3 Super Nintendo Power Switch Replacement: step 2, image 3 of 3
      • Carefully flip the unit back over.
      • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
      Ask FixBot
    1. Super Nintendo Power Switch Replacement, Power Switch: step 3, image 1 of 1
      • Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
      Ask FixBot
    2. Super Nintendo Power Switch Replacement: step 4, image 1 of 2 Super Nintendo Power Switch Replacement: step 4, image 2 of 2
      • The power switch is connected to the motherboard near the top left of the console.
      • Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
      • Do not detach the connector by pulling on the wires. This could damage the wires or the socket.
      Ask FixBot
17 other people completed this guide.
Author
with
Cameron Deines
736 Reputation
2 Guides authored
Cal Poly, Team 4-47, Amido Fall 2010 Member of Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Members
60 Guides authored
2 Guide Comments
Any tips on how to tell if it's the power switch that needs replacing vs something else?
TopShopGames - Reply Share
Look at it for any signs of physical damage, if you don't see any noticeable issues that you can fix then you can try cutting the two wires stripping off the ends of them, and very carefully touching the wires together while its plugged in. BE EXTREMELY CAREFUL WHILE DOING THIS DO NOT TOUCH THE EXPOSED WIRE. If you notice it turn on, immediately stop touching the wires together and unplug the console. This means that the switch itself is broken. If it doesn't turn on, stop touching the wire together and unplug the console. This means that it's likely a power cable issue.
Anders Hoff - Reply Share
Past 24 Hours: 8
Past 7 Days: 43
Past 30 Days: 179
All Time: 27,353
