Up to 20% off select tools
Super Nintendo Controller Port Replacement
Views: 38K
View statistics:
Past 24 Hours:
4
Past 7 Days:
46
Past 30 Days:
243
All Time:
38,189
Comments: 8
5 comments on steps, 3 guide comments.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 25
25 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will have you remove the upper case using a gamebit screwdriver and then in order to reveal the ribbon to the system from the controller port you will have to remove the reset button. This process will require only the gamebit.
    1. Super Nintendo Controller Port Replacement, Outer Case: step 1, image 1 of 1
      • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
      Ask FixBot
    2. Super Nintendo Controller Port Replacement: step 2, image 1 of 3 Super Nintendo Controller Port Replacement: step 2, image 2 of 3 Super Nintendo Controller Port Replacement: step 2, image 3 of 3
      • Carefully flip the unit back over.
      • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
      Ask FixBot
    1. Super Nintendo Controller Port Replacement, Eject Button: step 3, image 1 of 2 Super Nintendo Controller Port Replacement, Eject Button: step 3, image 2 of 2
      • Lift the right side of the eject lever out of the housing.
      Ask FixBot
    2. Super Nintendo Controller Port Replacement: step 4, image 1 of 3 Super Nintendo Controller Port Replacement: step 4, image 2 of 3 Super Nintendo Controller Port Replacement: step 4, image 3 of 3
      • Pull the metal bar out through the right side of the eject lever.
      • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
      • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
      Ask FixBot
    1. Super Nintendo Controller Port Replacement, Controller Port: step 5, image 1 of 1
      • Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
      Ask FixBot
    2. Super Nintendo Controller Port Replacement: step 6, image 1 of 2 Super Nintendo Controller Port Replacement: step 6, image 2 of 2
      • Carefully remove the ribbon cable from its port.
      Ask FixBot
18 other people completed this guide.
Author
with
James Shirley
1,039 Reputation
2 Guides authored
Cal Poly, Team 4-47, Amido Fall 2010 Member of Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Members
60 Guides authored
3 Guide Comments
I did a complete teardown of my 26 year old super Nintendo because I had to fix the AV jack. the hardest part was the de soldering. however upon putting it back together I could get the games to play, however it was in black and white…or even a grayish hue…and the controllers didn't work. shortly after the ribbon connecting the controller input to the system snapped on one end. do you think this was the issue, and where do I find a new one? Thanks.
Keith Goetting - Reply Share
This isn’t complete. How about taking the face plate off?
Daniel Powers - Reply Share
Find don’t look like screws they look like rivets
Steve Pitcher - Reply Share
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 243
All Time: 38,189
