Up to 20% off select tools
Sungale CyberUs Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
84
All Time:
688
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will include a walkthrough of how to change the screen of your tablet. It will include step by step process with notes on tools and materials needed.
    1. Sungale CyberUs Screen Replacement, Screen: step 1, image 1 of 1
      • Make sure to have the device turned off to prevent any minor electric shock.
      • Hold the device so the left side is facing towards you (like in the picture shown) so the two 4mm PH001 screws are exposed and easier to access.
      Ask FixBot
    2. Sungale CyberUs Screen Replacement: step 2, image 1 of 1
      • Remove both 4mm PH001 screws from the side panel.
      Ask FixBot
    3. Sungale CyberUs Screen Replacement: step 3, image 1 of 2 Sungale CyberUs Screen Replacement: step 3, image 2 of 2
      • Carefully pry up one of the top corners of the screen with a plastic spudger (prying tool). Slide the tool along the edges to release it from the housing.
      • The screen may make some cracking noises as you pry it from the casing. This is expected.
      • The screen is still connected to the motherboard. Use force with caution.
      Ask FixBot
    4. Sungale CyberUs Screen Replacement: step 4, image 1 of 1
      • Gently turn screen over, to the side, to reveal the ZIF connector attached to the motherboard.
      Ask FixBot
    5. Sungale CyberUs Screen Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Gently using tweezers, flip the black clip up. Pull the ZIF connector out.
      • You screen is still not completely detached from the device.
      Ask FixBot
    6. Sungale CyberUs Screen Replacement: step 6, image 1 of 2 Sungale CyberUs Screen Replacement: step 6, image 2 of 2
      • Using the prying tool, slide the black clip out. Pull the ZIF connector out and to the left, the screen is now detached from the motherboard.
      Ask FixBot
Author
with
Carolina Cardona
62 Reputation
1 Guide authored
IUPUI, Team 1-4, Harley Fall 2016 Member of IUPUI, Team 1-4, Harley Fall 2016
IUPUI-HARLEY-F16S1G4
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 84
All Time: 688
