Sungale CyberUs Battery Replacement
    1. Sungale CyberUs Battery Replacement, Screen: step 1, image 1 of 1
      • Make sure to have the device turned off to prevent any minor electric shock.
      • Hold the device so the left side is facing towards you (like in the picture shown) so the two 4mm PH001 screws are exposed and easier to access.
      Ask FixBot
    2. Sungale CyberUs Battery Replacement: step 2, image 1 of 1
      • Remove both 4mm PH001 screws from the side panel.
      Ask FixBot
    3. Sungale CyberUs Battery Replacement: step 3, image 1 of 2 Sungale CyberUs Battery Replacement: step 3, image 2 of 2
      • Carefully pry up one of the top corners of the screen with a plastic spudger (prying tool). Slide the tool along the edges to release it from the housing.
      • The screen may make some cracking noises as you pry it from the casing. This is expected.
      • The screen is still connected to the motherboard. Use force with caution.
      Ask FixBot
    4. Sungale CyberUs Battery Replacement: step 4, image 1 of 1
      • Gently turn screen over, to the side, to reveal the ZIF connector attached to the motherboard.
      Ask FixBot
    5. Sungale CyberUs Battery Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Gently using tweezers, flip the black clip up. Pull the ZIF connector out.
      • You screen is still not completely detached from the device.
      Ask FixBot
    6. Sungale CyberUs Battery Replacement: step 6, image 1 of 2 Sungale CyberUs Battery Replacement: step 6, image 2 of 2
      • Using the prying tool, slide the black clip out. Pull the ZIF connector out and to the left, the screen is now detached from the motherboard.
      Ask FixBot
    1. Sungale CyberUs Battery Replacement, Battery: step 7, image 1 of 1
      • Now, carefully we will remove the battery. Find the leads, or the red and black wires going to the battery from the motherboard. To free the wires you must cut the wire near the battery leads. Make sure both ends are clean and have enough exposed wire.
      Ask FixBot
    2. Sungale CyberUs Battery Replacement: step 8, image 1 of 1
      • You will have to clean the connections and solder the new battery back into place. Just as before, you want to reconnect the new battery to the motherboard.
      Ask FixBot
Grayson Heinbaugh
158 Reputation
1 Guide authored
IUPUI, Team 1-4, Harley Fall 2016 Member of IUPUI, Team 1-4, Harley Fall 2016
IUPUI-HARLEY-F16S1G4
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 450
