Sunbeam Mini Pie Maker FPSBPMM980 Disassembly
    1. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 1, image 1 of 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 1, image 2 of 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 1, image 3 of 3
      • Open the pie maker.
      • Remove four 4 mm screws holding the crescent-shaped black plastic plate in place with a Phillips #1 screwdriver.
      • Remove the black crescent-shaped plastic plate.
      Ask FixBot
    2. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 2, image 1 of 2 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 2, image 2 of 2
      • Repeat the previous step to remove the upper black crescent-shaped plastic plate from the upper half of the unit.
      • The pie maker's symmetrical construction may cause confusion—in this image the pie maker is resting on its upper half.
      Ask FixBot
    3. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 3, image 1 of 1
      • Remove the four 4 mm screws located directly on either side of the hinges with a Phillips #1 screwdriver.
      • Successfully removed screws will allow for the separation of the pan component from the outer plastic shell.
      Ask FixBot
    4. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 4, image 1 of 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 4, image 2 of 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 4, image 3 of 3
      • Remove the final two 4 mm screws from the circular black plastic bottom base plate with a Phillips #1 screwdriver.
      • Remove the black plastic base.
      Ask FixBot
    5. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 5, image 1 of 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 5, image 2 of 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 5, image 3 of 3
      • Disconnect the two red and green incandescent lights from their fixtures by popping them out of their red plastic cradles.
      Ask FixBot
    6. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 6, image 1 of 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 6, image 2 of 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 6, image 3 of 3
      • Examine successfully disassembled Sunbeam Mini Pie Maker FPSBPMM980.
      • If desired, remove insulatory coated paper cut outs to more easily access heating coils.
      Ask FixBot
    7. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: step 7, image 1 of 1
      • Examine electronics schematic.
      • The Sunbeam Pie Maker utilizes four heating coils to bring miniature pies to an internal temperature of 175+ F. The pies are placed in the appliance after pre-heating, and are cooked for approximately 10 minutes, or until golden brown. The machine begins pre-heating upon being plugged in, signifying it is receiving power with the red light.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Happy fixing!
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 349
