Sun King Solo Solar Lantern Hand Strap Replacement
    1. Sun King Solo Solar Lantern Hand Strap Replacement, Locate and Remove the Screws: step 1, image 1 of 1
      • Place the lamp LED side down on a clean workspace.
      • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
      Ask FixBot
    2. Sun King Solo Solar Lantern Hand Strap Replacement, Separate the Device: step 2, image 1 of 1
      • Gently pull the two halves of the lamp apart.
      Ask FixBot
    1. Sun King Solo Solar Lantern Hand Strap Replacement, Remove Strap: step 3, image 1 of 1
      • Remove both ends of the strap from the orange casing by pulling up.
      Ask FixBot
    2. Sun King Solo Solar Lantern Hand Strap Replacement, Replace the Strap: step 4, image 1 of 1
      • Insert the ends of the new strap into the strap housing on both sides of the orange component.
      • Either strap housing (inner or outer) can be used to adjust the strap length.
      Ask FixBot
Anna
613 Reputation
4 Guides authored
Michigan Tech, Team 1-3, Lauer Fall 2014 Member of Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 Members
21 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 638
