Sun King Solo Solar Lantern Device Seals Replacement
    1. Sun King Solo Solar Lantern Device Seals Replacement, Locate and Remove the Screws: step 1, image 1 of 1
      • Place the lamp LED side down on a clean workspace.
      • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
      Ask FixBot
    2. Sun King Solo Solar Lantern Device Seals Replacement, Separate the Device: step 2, image 1 of 1
      • Gently pull the two halves of the lamp apart.
      Ask FixBot
    1. Sun King Solo Solar Lantern Device Seals Replacement, O-ring Replacement: step 3, image 1 of 2 Sun King Solo Solar Lantern Device Seals Replacement, O-ring Replacement: step 3, image 2 of 2
      • On the clear upper half, remove the black O-ring
      • Place the new O-ring, making sure it is smooth all the way around
      Ask FixBot
    2. Sun King Solo Solar Lantern Device Seals Replacement, Stand Holder Replacements: step 4, image 1 of 1
      • Remove the rubber stand holders.
      • Place the new stand holders, making sure the wings of the holder are in the second opening
      Ask FixBot
Josef Simek
132 Reputation
1 Guide authored
Michigan Tech, Team 1-3, Lauer Fall 2014 Member of Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 Members
35 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 48
All Time: 947
