Summer LookOut Duo Motherboard and Display Replacement
    1. Summer LookOut Duo Motherboard and Display Replacement, Battery: step 1, image 1 of 3 Summer LookOut Duo Motherboard and Display Replacement, Battery: step 1, image 2 of 3 Summer LookOut Duo Motherboard and Display Replacement, Battery: step 1, image 3 of 3
      • Flip the device over so the back is facing up.
      • Remove the 9 mm screw using a Phillips #1 screwdriver.
      • Lift the battery panel away from the device.
      Ask FixBot
    2. Summer LookOut Duo Motherboard and Display Replacement: step 2, image 1 of 3 Summer LookOut Duo Motherboard and Display Replacement: step 2, image 2 of 3 Summer LookOut Duo Motherboard and Display Replacement: step 2, image 3 of 3
      • Flip the handheld monitor over and let the battery fall out into your hand.
      • Using angled tweezers, gently remove the plastic wire coupling from the side of the open battery compartment.
      • If the coupling struggles to release, with a loose but firm grip, slightly wiggle the plastic wire coupling back and forth until it releases.
      • Remove the battery from the device.
      Ask FixBot
    1. Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: step 3, image 1 of 3 Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: step 3, image 2 of 3 Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: step 3, image 3 of 3
      • Using the Phillips #00 screwdriver, remove the four 7mm screws from each corner on the back of the handheld monitor.
      • Remove the casing from the back of the handheld monitor.
      • A nylon spudger may be helpful to pry the case open.
      • Using the angled tweezers, gently remove the plastic wire coupling connecting the speaker to the motherboard.
      • The power button may come loose as the case is being removed.
      Ask FixBot
    2. Summer LookOut Duo Motherboard and Display Replacement: step 4, image 1 of 2 Summer LookOut Duo Motherboard and Display Replacement: step 4, image 2 of 2
      • Remove the motherboard and monitor display together and set aside.
      Ask FixBot
Adrianna Piedra
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 49
All Time: 246
