Introduction
Go to step 1 ↓If your Summer LookOut Duo baby monitor cameras are having trouble staying in position or they broke, then you may need to replace the stand. This step-by-step guide goes through how to replace the stand of baby monitor cameras.
Before proceeding, make sure the device is powered off and dry to avoid internal damage to the device or potential shock hazards.
CHOKING HAZARD: This device contains small screws. If possible, use a magnetic mat or small container within eyesight to keep track of the screws to prevent possible ingestion or misplacement.
Tools
Remove the plastic wall mount attached to the base of the stand.
Remove the four 9 mm screws on the back four corners of the camera using a Phillips #00 screwdriver.
Remove the two 8 mm screws near the bottom center of the back of the camera using a Phillips #00 screwdriver.
