Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Sudden Power Offs
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
49
All Time:
49
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Easy
Community-Contributed Guide
Sudden Power Offs
Introduction
Go to step 1 ↓
The All-in-One PC Engine
The PC Engine Duo-R is the 1993 version of NEC's Duo family: it combines the PC Engine console and the Super CD-ROM² player into a single housing, allowing you to use both HuCards and CD games without extra modules. Compared to the original Duo, it is a cost-optimized version, but it remains one of the most beloved consoles for PC Engine collectors.
The Problem: It Turns Off When Moved
The client reported a very specific issue: the console worked, but it would turn off as soon as it was moved or the power cable was nudged. This is the classic symptom of cold solder joints, particularly in the area of the power socket.
A cold solder joint is a tin joint that, over the years, due to heat and cold cycles and the mechanical stress from cables and connectors, cracks around the pin. The contact remains, but it is precarious: even a small vibration is enough to interrupt it for an instant, and the console turns off. On power connections, which carry more current and endure the strain of the cable, the problem appears sooner than elsewhere.
    1. Sudden Power Offs, Sudden Power Offs: step 1, image 1 of 3 Sudden Power Offs, Sudden Power Offs: step 1, image 2 of 3 Sudden Power Offs, Sudden Power Offs: step 1, image 3 of 3
      • Motherboard with visible cold solder joints
      Ask FixBot
The Diagnosis
I opened the console and inspected the solder side of the board with a magnifying glass: in addition to the power socket, several solder joints on the connectors and larger components showed the classic fracture ring around the pin and a dull appearance, a sign of a worn-out joint.
The Repair
Reflowing the Cold Solder Joints
I carefully reflowed all the cold solder joints I found, starting with the power socket and continuing with the connectors and components under stress. For each joint, I removed the old solder where necessary and applied new solder with flux until I achieved a shiny, well-wetted joint on both the pin and the pad. It is a patient job: a hastily reflowed joint risks becoming the next cold solder joint.
Ultrasonic Board Cleaning
Finally, I cleaned the board in the ultrasonic cleaner with isopropyl alcohol, removing flux residue from the new solder joints, as well as dust and dirt accumulated over the years. After complete drying, the board was clean and ready for reassembly.
The Testing
Once the console was closed, I tested it extensively, both via HuCard using a Turbo EverDrive and via CD, with the NEC joypad. I intentionally moved the console and the power cable, recreating the same conditions that previously caused the power-off: no interruptions, stable image and audio. The Duo-R is reliable once again.
Giovanni Casale PCRETROLAB
51 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 49
All Time: 49
