Subaru Legacy 2009 Key Fob Battery Replacement
  1. Subaru Legacy 2009 Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 2 Subaru Legacy 2009 Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove a 5.0 mm screw from the base of the key fob.
    Ask FixBot
  2. Subaru Legacy 2009 Key Fob Battery Replacement: step 2, image 1 of 2 Subaru Legacy 2009 Key Fob Battery Replacement: step 2, image 2 of 2
    • Place the flat end of a spudger into the gap between the key blank (metal part) and the case.
    • Gently pry upward to separate the housing.
    Ask FixBot
  3. Subaru Legacy 2009 Key Fob Battery Replacement: step 3, image 1 of 1
    • Once the case comes apart, turn the key upside down, and the keyless fob should easily come out.
    Ask FixBot
  4. Subaru Legacy 2009 Key Fob Battery Replacement: step 4, image 1 of 3 Subaru Legacy 2009 Key Fob Battery Replacement: step 4, image 2 of 3 Subaru Legacy 2009 Key Fob Battery Replacement: step 4, image 3 of 3
    • Use a spudger or your fingernails to pry open the four clips securing the keyless fob.
    • Ensure that you pinch the fob on the side, not the top, during the opening to avoid accidentally re-securing the clips.
    Ask FixBot
  5. Subaru Legacy 2009 Key Fob Battery Replacement: step 5, image 1 of 3 Subaru Legacy 2009 Key Fob Battery Replacement: step 5, image 2 of 3 Subaru Legacy 2009 Key Fob Battery Replacement: step 5, image 3 of 3
    • Gently slide a spudger beneath the battery to lift it from the case.
    • Replace it with a new CR1620 3V lithium coin battery.
    • Reassemble the key fob.
    Ask FixBot
Brandon Lu
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 58
All Time: 1,285
