Stratocaster Loose Switch Wire Reattachment
    1. Stratocaster Loose Switch Wire Reattachment, Stratocaster Loose Switch Wire Reattachment: step 1, image 1 of 3 Stratocaster Loose Switch Wire Reattachment, Stratocaster Loose Switch Wire Reattachment: step 1, image 2 of 3 Stratocaster Loose Switch Wire Reattachment, Stratocaster Loose Switch Wire Reattachment: step 1, image 3 of 3
      • Remove the screws from the backplate on the back of the guitar.
      • Fully remove the backplate and set it aside.
      Ask FixBot
    2. Stratocaster Loose Switch Wire Reattachment: step 2, image 1 of 2 Stratocaster Loose Switch Wire Reattachment: step 2, image 2 of 2
      • Fully loosen all guitar strings by turning the tuning pegs towards the body when held in the orientation of the picture.
      Ask FixBot
    3. Stratocaster Loose Switch Wire Reattachment: step 3, image 1 of 3 Stratocaster Loose Switch Wire Reattachment: step 3, image 2 of 3 Stratocaster Loose Switch Wire Reattachment: step 3, image 3 of 3
      • Insert a finger under the strings to create some slack.
      • Use pliers to cut through each of the strings.
      Ask FixBot
    4. Stratocaster Loose Switch Wire Reattachment: step 4, image 1 of 2 Stratocaster Loose Switch Wire Reattachment: step 4, image 2 of 2
      • Remove the strings from the guitar tuning pegs.
      Ask FixBot
    5. Stratocaster Loose Switch Wire Reattachment: step 5, image 1 of 3 Stratocaster Loose Switch Wire Reattachment: step 5, image 2 of 3 Stratocaster Loose Switch Wire Reattachment: step 5, image 3 of 3
      • From the front, push in the guitar strings until they peek out of the back.
      • From the back, pull the guitar strings all the way out.
      Ask FixBot
    6. Stratocaster Loose Switch Wire Reattachment: step 6, image 1 of 3 Stratocaster Loose Switch Wire Reattachment: step 6, image 2 of 3 Stratocaster Loose Switch Wire Reattachment: step 6, image 3 of 3
      • Remove all of the screws from the front panel.
      • Fully remove the front panel to reveal wires and the switch circuit board.
      Ask FixBot
    7. Stratocaster Loose Switch Wire Reattachment: step 7, image 1 of 3 Stratocaster Loose Switch Wire Reattachment: step 7, image 2 of 3 Stratocaster Loose Switch Wire Reattachment: step 7, image 3 of 3
      • Identify the loose string and which lug (point on the switch) it needs to be reattached to. It will be the one that doesnt have a string attached.
      • Re-solder the loose wire to the switch.
      Ask FixBot
    8. Stratocaster Loose Switch Wire Reattachment: step 8, image 1 of 3 Stratocaster Loose Switch Wire Reattachment: step 8, image 2 of 3 Stratocaster Loose Switch Wire Reattachment: step 8, image 3 of 3
      • Place the front panel back in its original position.
      • Screw in all of the screws to reattach and secure the front panel.
      Ask FixBot
    9. Stratocaster Loose Switch Wire Reattachment: step 9, image 1 of 2 Stratocaster Loose Switch Wire Reattachment: step 9, image 2 of 2
      • From the back of the guitar, insert new guitar strings one-by-one, in order from thickest to thinnest.
      • From the front, pull the string all the way through until it catches.
      Ask FixBot
    10. Stratocaster Loose Switch Wire Reattachment: step 10, image 1 of 2 Stratocaster Loose Switch Wire Reattachment: step 10, image 2 of 2
      • One-by-one, pull each guitar string taut and cut off any excess string. Be sure to leave enough string to work with for the next step.
      Ask FixBot
    11. Stratocaster Loose Switch Wire Reattachment: step 11, image 1 of 2 Stratocaster Loose Switch Wire Reattachment: step 11, image 2 of 2
      • Insert the loose end of the guitar string into the corresponding tuning post.
      • Hold the string in place while turning the tuning peg to tighten and secure the guitar string.
      • Repeat for all 6 strings.
      Ask FixBot
    12. Stratocaster Loose Switch Wire Reattachment: step 12, image 1 of 3 Stratocaster Loose Switch Wire Reattachment: step 12, image 2 of 3 Stratocaster Loose Switch Wire Reattachment: step 12, image 3 of 3
      • Place the backplate back in its original place.
      • Reattach all of the screws.
      Ask FixBot
Finish Line
Nathan Bao
205 Reputation
1 Guide authored
UC Davis, Team 1-4, Morris Winter 2026 Member of UC Davis, Team 1-4, Morris Winter 2026
UCD-MORRIS-W26S1G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 24
All Time: 116
