Up to 20% off select tools
Sticky Key Saxophone Fix
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
169
All Time:
3,016
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
Hello this guide is to be used for sticking keys on a saxophone; however, this guide should be used as a last resort if cleaning the pad on the key did not solve the problem. Most sticking keys can be solved easily by simply cleaning the pad, but in extreme cases it may be deemed necessary to loosen the key itself.
    1. Sticky Key Saxophone Fix, Sticky Key Saxophone Fix: step 1, image 1 of 1
      • Locate sticking key.
      Ask FixBot
    2. Sticky Key Saxophone Fix: step 2, image 1 of 1
      • Screws are located down from key.
      Ask FixBot
    3. Sticky Key Saxophone Fix: step 3, image 1 of 1
      • Loosen screw slowly and carefully, so that screw isn't lost.
      Ask FixBot
    4. Sticky Key Saxophone Fix: step 4, image 1 of 1
      • Test key and note free movement.
      Ask FixBot
    5. Sticky Key Saxophone Fix: step 5, image 1 of 1
      • Put saxophone completely together and test out key.
      • If key still sticks repeat previous steps.
      Ask FixBot
Loosen screw until key moves freely or as desired. Once as desired, you are then ready to play the instrument and test out key!
Author
with
AlysonStrange
101 Reputation
1 Guide authored
1 Guide Comment
An Issue I have with a sticky key on my Alto Saxophpone. I found a remedy on ifixit.com, a hack recommended for fixing pretty much anything! Try it out!!
kwiggins01 - Reply Share
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 169
All Time: 3,016
