Steelseries Rival 3 Scroll Wheel Replacement
    1. Steelseries Rival 3 Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 1
      • Disconnect the mouse from your laptop/personal computer.
      Ask FixBot
    2. Steelseries Rival 3 Scroll Wheel Replacement: step 2, image 1 of 2 Steelseries Rival 3 Scroll Wheel Replacement: step 2, image 2 of 2
      • Remove the three mouse skates with a prying tool.
      • Your prying tool may slip when removing the skates so proceed with caution.
      • If new skates are needed, purchase them at SteelSeries Rival 3 Mouse Skates.
      Ask FixBot
    3. Steelseries Rival 3 Scroll Wheel Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the four screws from the base of the mouse and remove the casing.
      Ask FixBot
    4. Steelseries Rival 3 Scroll Wheel Replacement: step 4, image 1 of 1
      • Remove the wire that is connected to the circuit board of the mouse as shown in the image.
      • The wire and the socket can be damaged if not handled with care.
      Ask FixBot
    5. Steelseries Rival 3 Scroll Wheel Replacement: step 5, image 1 of 1
      • Carefully take off the circuit board and lay it on the surface being used.
      • Be careful when doing so to prevent the wire connected to the base of the mouse from breaking.
      Ask FixBot
    6. Steelseries Rival 3 Scroll Wheel Replacement: step 6, image 1 of 2 Steelseries Rival 3 Scroll Wheel Replacement: step 6, image 2 of 2
      • Remove the four black screws along the circuit board using a Phillips #0 screwdriver.
      Ask FixBot
    7. Steelseries Rival 3 Scroll Wheel Replacement: step 7, image 1 of 1
      • Remove the scroll wheel by taking it out of its socket.
      • The socket is the silver tower that allows the mouse to turn while keeping the scroll wheel stiff.
      Ask FixBot
    8. Steelseries Rival 3 Scroll Wheel Replacement: step 8, image 1 of 1
      • Insert your new scroll wheel into the tower where the scroll wheel was originally.
      • Ensure not to apply excessive force during the process.
      • Before you put the mouse back together, make sure the scroll wheel turns smoothly in order for the mouse to work.
      Ask FixBot
3 other people completed this guide.
Noah Perlmutar
205 Reputation
1 Guide authored
3 Guide Comments
in need help there i no place i can find that actually has the right one please help
Wynter Merritt - Reply Share
you can't find the part? because i just found one on aliexpress for 5 dollars..
unless ur in a diff country, in which case tell me where and ill see if i can help you
hellonearth311 - Reply Share
I did the steps based on your description.
I needed to do an extra step because I had to replace the scroll digitizer on the circuit board as well because it was working very unstable.
Now everything works fine, thanks for your description.
Tofi - Reply Share
Past 24 Hours: 7
Past 7 Days: 78
Past 30 Days: 310
All Time: 10,344
