SteelSeries Stratus Duo Battery Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
57
All Time:
1,408
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn out or dead battery in a SteelSeries Stratus Duo controller.
For your safety, discharge the battery below 25% before disassembling your controller. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive when reassembling your device.
Parts
Tools
    1. SteelSeries Stratus Duo Battery Replacement, Remove the sticker: step 1, image 1 of 2 SteelSeries Stratus Duo Battery Replacement, Remove the sticker: step 1, image 2 of 2
      • Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
      • If you have trouble removing the sticker, heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath. You can also use a hair dryer to soften the adhesive.
      Ask FixBot
    2. SteelSeries Stratus Duo Battery Replacement, Unscrew the back cover: step 2, image 1 of 1
      • Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
      Ask FixBot
    3. SteelSeries Stratus Duo Battery Replacement, Reposition the back cover assembly: step 3, image 1 of 3 SteelSeries Stratus Duo Battery Replacement, Reposition the back cover assembly: step 3, image 2 of 3 SteelSeries Stratus Duo Battery Replacement, Reposition the back cover assembly: step 3, image 3 of 3
      • Don't try to remove the back cover assembly all the way yet, as it's still connected to the mainboard.
      • Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
      Ask FixBot
    4. SteelSeries Stratus Duo Battery Replacement, Disconnect the interconnect cable: step 4, image 1 of 3 SteelSeries Stratus Duo Battery Replacement, Disconnect the interconnect cable: step 4, image 2 of 3 SteelSeries Stratus Duo Battery Replacement, Disconnect the interconnect cable: step 4, image 3 of 3
      • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
      Ask FixBot
    5. SteelSeries Stratus Duo Battery Replacement: step 5, image 1 of 2 SteelSeries Stratus Duo Battery Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of blunt nosed tweezers or your fingers to pull the cable out of the socket.
      Ask FixBot
    6. SteelSeries Stratus Duo Battery Replacement, Disconnect the battery cable: step 6, image 1 of 3 SteelSeries Stratus Duo Battery Replacement, Disconnect the battery cable: step 6, image 2 of 3 SteelSeries Stratus Duo Battery Replacement, Disconnect the battery cable: step 6, image 3 of 3
      • Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
      Ask FixBot
    7. SteelSeries Stratus Duo Battery Replacement, Remove the back cover assembly: step 7, image 1 of 1
      • Remove the back cover assembly.
      Ask FixBot
    1. SteelSeries Stratus Duo Battery Replacement, Pry up the battery: step 8, image 1 of 2 SteelSeries Stratus Duo Battery Replacement, Pry up the battery: step 8, image 2 of 2
      • The battery is held in place by mild adhesive.
      • Insert the long edge of an opening pick into the gap between the battery and the back cover assembly.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Use the opening pick to carefully pry up the battery and separate the adhesive.
      Ask FixBot
    2. SteelSeries Stratus Duo Battery Replacement, Remove the battery: step 9, image 1 of 3 SteelSeries Stratus Duo Battery Replacement, Remove the battery: step 9, image 2 of 3 SteelSeries Stratus Duo Battery Replacement, Remove the battery: step 9, image 3 of 3
      • Grab the battery with your fingers and lift it out of its recess to remove it.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • During reassembly make sure to align the battery and the back cover correctly.
      • During reassembly, follow this guide if you are using a pre-cut adhesive card.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Adriana Zwink
69,307 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 57
All Time: 1,408
