SteelSeries Nimbus+ Thumbsticks Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
9
Past 7 Days:
23
Past 30 Days:
86
All Time:
2,306
Comments: 3
3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove the thumbsticks in your SteelSeries Nimbus+ controller.
Tools
    1. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the phone mount: step 1, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Remove the phone mount: step 1, image 2 of 2
      • Use your fingers to remove the phone mount by pulling it straight out of the controller.
      Ask FixBot
    2. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the sticker: step 2, image 1 of 1
      • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
      • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
      Ask FixBot
    3. SteelSeries Nimbus+ Thumbsticks Replacement, Unscrew the back cover: step 3, image 1 of 1
      • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
      Ask FixBot
    4. SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: step 4, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: step 4, image 2 of 2
      • The back cover is held in place by plastic clips.
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
      Ask FixBot
    5. SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: step 5, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: step 5, image 2 of 2
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
      Ask FixBot
    6. SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: step 6, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: step 6, image 2 of 2
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
      Ask FixBot
    7. SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: step 7, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: step 7, image 2 of 2
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
      Ask FixBot
    8. SteelSeries Nimbus+ Thumbsticks Replacement, Unfold the back cover assembly: step 8, image 1 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Unfold the back cover assembly: step 8, image 2 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Unfold the back cover assembly: step 8, image 3 of 3
      • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
      • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
      Ask FixBot
    9. SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the battery cable: step 9, image 1 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the battery cable: step 9, image 2 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the battery cable: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
      Ask FixBot
    10. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the back cover assembly: step 10, image 1 of 1
      • Remove the back cover assembly.
      Ask FixBot
    1. SteelSeries Nimbus+ Thumbsticks Replacement, Unscrew the board: step 11, image 1 of 1
      • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
      Ask FixBot
    2. SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the thumbstick board: step 12, image 1 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the thumbstick board: step 12, image 2 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the thumbstick board: step 12, image 3 of 3
      • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
      Ask FixBot
    3. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the board: step 13, image 1 of 1
      • Remove the board with the thumbsticks from the mainboard.
      Ask FixBot
Repair didn’t go as planned? Check our Answers community for help.
2 other people completed this guide.
Adriana Zwink
69,307 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
3 Guide Comments
how can we find a replacement board with the thumbsticks?
Anne Taylor - Reply Share
I wonder the same thing
Bizkot - Reply Share
Any one found the replacement thumbsticks for the Nimbus+?
Igor Bond - Reply Share
Past 24 Hours: 9
Past 7 Days: 23
Past 30 Days: 86
All Time: 2,306
