Up to 20% off select tools
SteelSeries Nimbus+ Mainboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
75
All Time:
878
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use to remove the mainboard in your SteelSeries Nimbus+ controller.
A completely removed mainboard simplifies desoldering parts like the charging port.
    1. SteelSeries Nimbus+ Mainboard Replacement, Remove the phone mount: step 1, image 1 of 2 SteelSeries Nimbus+ Mainboard Replacement, Remove the phone mount: step 1, image 2 of 2
      • Use your fingers to remove the phone mount by pulling it straight out of the controller.
      Ask FixBot
    2. SteelSeries Nimbus+ Mainboard Replacement, Remove the sticker: step 2, image 1 of 1
      • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
      • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
      Ask FixBot
    3. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the back cover: step 3, image 1 of 1
      • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
      Ask FixBot
    4. SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: step 4, image 1 of 2 SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: step 4, image 2 of 2
      • The back cover is held in place by plastic clips.
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
      Ask FixBot
    5. SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: step 5, image 1 of 2 SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: step 5, image 2 of 2
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
      Ask FixBot
    6. SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: step 6, image 1 of 2 SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: step 6, image 2 of 2
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
      Ask FixBot
    7. SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: step 7, image 1 of 2 SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: step 7, image 2 of 2
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
      Ask FixBot
    8. SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: step 8, image 1 of 3 SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: step 8, image 2 of 3 SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: step 8, image 3 of 3
      • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
      • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
      Ask FixBot
    9. SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: step 9, image 1 of 3 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: step 9, image 2 of 3 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
      Ask FixBot
    10. SteelSeries Nimbus+ Mainboard Replacement, Remove the back cover assembly: step 10, image 1 of 1
      • Remove the back cover assembly.
      Ask FixBot
    1. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the board: step 11, image 1 of 1
      • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
      Ask FixBot
    2. SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: step 12, image 1 of 3 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: step 12, image 2 of 3 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: step 12, image 3 of 3
      • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
      Ask FixBot
    3. SteelSeries Nimbus+ Mainboard Replacement, Remove the board: step 13, image 1 of 1
      • Remove the board with the thumbsticks from the mainboard.
      Ask FixBot
    1. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the mainboard: step 14, image 1 of 1
      • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
      Ask FixBot
    2. SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: step 15, image 1 of 3 SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: step 15, image 2 of 3 SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: step 15, image 3 of 3
      • Use your fingers to lift up the mainboard from the front case.
      • Remove the mainboard.
      Ask FixBot
    1. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the triggers: step 16, image 1 of 1
      • Use a Phillips screwdriver to remove the four screws securing the triggers on the motherboard.
      Ask FixBot
    2. SteelSeries Nimbus+ Mainboard Replacement, Release the right trigger: step 17, image 1 of 2 SteelSeries Nimbus+ Mainboard Replacement, Release the right trigger: step 17, image 2 of 2
      • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
      Ask FixBot
    3. SteelSeries Nimbus+ Mainboard Replacement, Release the left trigger: step 18, image 1 of 2 SteelSeries Nimbus+ Mainboard Replacement, Release the left trigger: step 18, image 2 of 2
      • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
      Ask FixBot
    4. SteelSeries Nimbus+ Mainboard Replacement, Remove the mainboard: step 19, image 1 of 1
      • Compare your new mainboard with the original mainboard. It may be necessary to transfer over some components. For this, you may have to unsolder the trigger buttons or attach the rubber covers to the new mainboard.
      Ask FixBot
Adriana Zwink
69,920 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 75
All Time: 878
