SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement
  1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: step 1, image 1 of 3 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: step 1, image 2 of 3 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: step 1, image 3 of 3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
    Ask FixBot
  2. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: step 2, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: step 2, image 2 of 2
    • Remove the control wheel from the GameDAC by pulling on the knob.
    Ask FixBot
  3. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: step 3, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: step 3, image 2 of 2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
    Ask FixBot
  4. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: step 4, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: step 4, image 2 of 2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
    Ask FixBot
  5. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: step 5, image 1 of 1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
    Ask FixBot
  6. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: step 6, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: step 6, image 2 of 2
    • Desolder the four button pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
    Ask FixBot
3 other people completed this guide.
Kyle Chang
1,170 Reputation
7 Guides authored
Cal Poly, Team S18-G1, White Winter 2019 Member of Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,627
