SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement
  1. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Ear Cushion: step 1, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Ear Cushion: step 1, image 2 of 2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
    Ask FixBot
  2. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Circuit Board: step 2, image 1 of 1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
    Ask FixBot
  3. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 3, image 1 of 1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
    Ask FixBot
  4. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 4, image 1 of 1
    • Remove the three 5mm screws using a Phillips #0 driver head.
    Ask FixBot
  5. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 5, image 1 of 1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
    Ask FixBot
  6. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Microphone Cable: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Pull up on the wires connected to the circuit board using tweezers to remove the circuit board from inside the headset.
    Ask FixBot
  7. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 7, image 1 of 1
    • Desolder the six wired connections on the circuit board.
    • For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
    Ask FixBot
  8. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 8, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 8, image 2 of 2
    • Lift up the wire on the rotating wheel with tweezers to move it out of the way of the screws.
    • Remove the two 5mm screws with a Phillips #0 driver head.
    Ask FixBot
  9. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 9, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 9, image 2 of 2
    • Pull out the rotating wheel from the headset casing.
    • Remove the microphone from the casing with the rotator wheel.
    • After removing the rotating wheel, lift the wheel up and use your other hand to feed the microphone through the case.
    Ask FixBot
  10. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 10, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: step 10, image 2 of 2
    • Pull the microphone wire out of the wheel.
    • Forcefully removing the microphone from the wheel may break the plastic wheel.
    • Pull the wire and wheel apart to remove the entire component.
    Ask FixBot
8 other people completed this guide.
Vanessa Beeler
311 Reputation
1 Guide authored
Cal Poly, Team S18-G1, White Winter 2019 Member of Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 Members
22 Guides authored
9 Guide Comments
can Ii do this with my Arctis 5?
Vantura - Reply Share
Ugh! Why do they all fail at mic design so bad? Something that has been mastered for decades. It blows my mind.
Chris - Reply Share
Is there any place where i can get this cable? I also need a new mic for the wireless pro but steelseries dont sell parts. Somehow it came off and i lost it.
robinmusch - Reply Share
&&^& my mic died and i don’t have warranty wtf -_-
taps_so - Reply Share
The left earpiece on mine has a different screw type than phillips for some reason. I think it’s a kind of hex screw but I have hex heads and none worked. Strange that the left and right earpieces use different screws.
Darren Peterson - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 145
All Time: 16,339
