SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement
  1. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Ear Cushion: step 1, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Ear Cushion: step 1, image 2 of 2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Circuit Board: step 2, image 1 of 1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: step 3, image 1 of 1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: step 4, image 1 of 1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: step 5, image 1 of 1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button Cap: step 6, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button Cap: step 6, image 2 of 2
    • Flip the circuit board over and remove the keycap by pulling on it.
  7. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button: step 7, image 1 of 1
    • Desolder the wires connecting the button to the circuit board.
    • For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
  8. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: step 8, image 1 of 2 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: step 8, image 2 of 2
    • Desolder the three pins to remove the button from the circuit board.
Kyle Chang
1,170 Reputation
7 Guides authored
Cal Poly, Team S18-G1, White Winter 2019 Member of Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 Members
22 Guides authored
10 Guide Comments
Where can you get the replacement switch?
Jason Rosa - Reply Share
Can you provide any specs for this switch? I’d like to buy the replacement switch before disassembling the headset.
DAA - Reply Share
I also need to know where to get the replacement switch from !
Trevor Peters - Reply Share
If anyone wants to try it (I have not), I think the G type switch will work. BUT you will have to find a way to mount it, as it does not have the Metal case for soldering to the PCB.
Searchebay.co.uk for 11 Types, DPDT Self Latching Locking Momentary Push Button PCB SMD Switch 6 Pin
Select Type G
Try at your own risk and good luck
BTW, the size of the switch is 5.8 x 5.8 mm
DAA - Reply Share
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 93
All Time: 12,839
