SteelSeries Arctis Pro Microphone Cable Replacement
    1. SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: step 1, image 1 of 2 SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: step 1, image 2 of 2
      • Remove ear cushion by pulling the cushion up and towards yourself.
      • Repeat this motion around the cushion until it comes free.
      Ask FixBot
    2. SteelSeries Arctis Pro Microphone Cable Replacement: step 2, image 1 of 2 SteelSeries Arctis Pro Microphone Cable Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 3 case screws.
      • Lift the driver assembly away from the rest of the housing.
      Ask FixBot
    3. SteelSeries Arctis Pro Microphone Cable Replacement: step 3, image 1 of 3 SteelSeries Arctis Pro Microphone Cable Replacement: step 3, image 2 of 3 SteelSeries Arctis Pro Microphone Cable Replacement: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three 5 mm screws.
      • Push the headset volume dial in-words towards the housing while simultaneously pulling the board towards yourself.
      Ask FixBot
    4. SteelSeries Arctis Pro Microphone Cable Replacement: step 4, image 1 of 1
      • De-solder the six connections on the side of the main board.
      Ask FixBot
    5. SteelSeries Arctis Pro Microphone Cable Replacement: step 5, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two 5 mm screws that secure the microphone holder.
      Ask FixBot
    6. SteelSeries Arctis Pro Microphone Cable Replacement: step 6, image 1 of 3 SteelSeries Arctis Pro Microphone Cable Replacement: step 6, image 2 of 3 SteelSeries Arctis Pro Microphone Cable Replacement: step 6, image 3 of 3
      • Pull the microphone assembly and cable out of the housing and out towards you until it comes free.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 99
All Time: 3,011
