Introduction
Go to step 1 ↓If the volume scroll wheel is not adjusting the volume or rotating as it should be, follow this guide to replace the wheel.
Caution: Ensure hands are dry. Moisture could mess up the wiring. Be gentle and remove necessary pieces carefully to not break the device.
Tools
Remove the ear cushion on the left ear muff
This is done by pulling slightly on the outside of the cushion and moving around it until it comes off
5 other people completed this guide.
4 Guide Comments
thanks for the tutorial
I have the equipment and skills to do this repair, but need to source parts.
Where would I get a replacement wheel and what would be the part #?
My wheel is starting to fail and as I adjust it, one earpiece cuts in and out. There is also a scratching/static sound as I turn the wheel
I am also searching for parts, Did you ever find some?
A potential replacement is this part from digikey. I used it to fix my broken ChatMix wheel here: SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement
but you won’t be able to click in order to cycle on the base station with this replacement part ?
