SteelSeries Apex 64145 LED Replacement
    1. SteelSeries Apex 64145 LED Replacement, Gel Membrane: step 1, image 1 of 1
      • Unplug the keyboard from the computer.
      Ask FixBot
    2. SteelSeries Apex 64145 LED Replacement: step 2, image 1 of 1
      • Unscrew the twenty black 4.5 mm Phillips #1 screws on the back of the keyboard.
      Ask FixBot
    3. SteelSeries Apex 64145 LED Replacement: step 3, image 1 of 1
      • Pry open the back of the keyboard.
      Ask FixBot
    4. SteelSeries Apex 64145 LED Replacement: step 4, image 1 of 2 SteelSeries Apex 64145 LED Replacement: step 4, image 2 of 2
      • Remove the gel membrane.
      Ask FixBot
    1. SteelSeries Apex 64145 LED Replacement, LED: step 5, image 1 of 2 SteelSeries Apex 64145 LED Replacement, LED: step 5, image 2 of 2
      • Unscrew the two silver 4.0 mm Phillips #1 screws and the three black 6.5 mm Phillips #1 screws holding the silicone sheets.
      Ask FixBot
    2. SteelSeries Apex 64145 LED Replacement: step 6, image 1 of 1
      • Flip the chip slightly in order to remove the sheets.
      Ask FixBot
    3. SteelSeries Apex 64145 LED Replacement: step 7, image 1 of 1
      • Remove the sheets.
      Ask FixBot
    4. SteelSeries Apex 64145 LED Replacement: step 8, image 1 of 2 SteelSeries Apex 64145 LED Replacement: step 8, image 2 of 2
      • Unscrew the two silver 4.5 mm Phillips #1 screws and the seven 5.0 mm Phillips #1 screws that deter the plastic panel from removal.
      Ask FixBot
    5. SteelSeries Apex 64145 LED Replacement: step 9, image 1 of 1
      • Remove the plastic panel and the white sheet.
      Ask FixBot
    6. SteelSeries Apex 64145 LED Replacement: step 10, image 1 of 3 SteelSeries Apex 64145 LED Replacement: step 10, image 2 of 3 SteelSeries Apex 64145 LED Replacement: step 10, image 3 of 3
      • Unplug the wires connected to the LEDs.
      Ask FixBot
    7. SteelSeries Apex 64145 LED Replacement: step 11, image 1 of 2 SteelSeries Apex 64145 LED Replacement: step 11, image 2 of 2
      • Remove the LEDs.
      Ask FixBot
Zwe Phone Shein
559 Reputation
5 Guides authored
USF Tampa, Team S1-G1, Nance Spring 2017 Member of USF Tampa, Team S1-G1, Nance Spring 2017
USFT-NANCE-S17S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 45
Past 30 Days: 190
All Time: 19,044
