SteelSeries Apex 3 TKL Keys Replacement
  1. SteelSeries Apex 3 TKL Keys Replacement, Back Panel: step 1, image 1 of 1
    • Use a JIS #00 screwdriver to remove all back panel screws.
    Ask FixBot
  2. SteelSeries Apex 3 TKL Keys Replacement: step 2, image 1 of 2 SteelSeries Apex 3 TKL Keys Replacement: step 2, image 2 of 2
    • Use the iFixit opening pick to pry open the back panel by running it along the edges of the keyboard.
    Ask FixBot
  3. SteelSeries Apex 3 TKL Keys Replacement, Rubber Membrane: step 3, image 1 of 1
    • Lift off the rubber membrane.
    • When replacing, make sure the back stubs align with the back of each key on the keyboard.
    Ask FixBot
  4. SteelSeries Apex 3 TKL Keys Replacement, Keys: step 4, image 1 of 1
    • Use a screwdriver to remove the screws securing the plastic backing on the keys.
    Ask FixBot
  5. SteelSeries Apex 3 TKL Keys Replacement: step 5, image 1 of 1
    • You can use the spudger to press out specific keys that are dirty or for key cap replacement
    Ask FixBot
Nicholas Medeiros
289 Reputation
3 Guides authored
1 Guide Comment
how do you detach the connection in the middle on the lower side, the where the logo is positioned?
i can get all the other ones to detach just this little magnet or hatch doesnt want to detach. i tried poking a pick and a screwdriver beneath it, they just started scratching of material from the backplatte. I would be grateful if you could tell me how i can detach that last piece. look forward to it!
Dodo - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 150
All Time: 2,597
