Up to 20% off select tools
Steam Machine (2026) SSD Replacement
Views: 8.9K
View statistics:
Past 24 Hours:
276
Past 7 Days:
1,944
Past 30 Days:
5,007
All Time:
8,900
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace or upgrade the SSD (aka storage) in your Valve Steam Machine (2026).
The Steam Machine has a single M.2 NVMe slot that's compatible with 2230 or 2280 form factors.
These steps only describe how to physically remove and replace your SSD. You'll need additional software tools and procedures to install an OS and get the replacement SSD to function as intended.
Follow Valve's SteamOS installation instructions to install, re-image, or repair SteamOS on your Steam Machine. Follow Valve's Steam Deck recovery instructions to reset or recover SteamOS on your device. For installing Windows, official resources can be found here.
    1. Steam Machine (2026) SSD Replacement, Before you begin: step 1, image 1 of 3 Steam Machine (2026) SSD Replacement, Before you begin: step 1, image 2 of 3 Steam Machine (2026) SSD Replacement, Before you begin: step 1, image 3 of 3
      • Before you begin this repair:
      • Power down your Steam Machine and disconnect the power cable.
      • Unplug any remaining cables or accessories from all ports.
      • If you have a microSD card installed, remove it. Otherwise, it may break during this procedure.
      Ask FixBot
    1. Steam Machine (2026) SSD Replacement, Reposition the Steam Machine: step 2, image 1 of 1
      • Reposition the Steam Machine so the bottom is facing up.
      Ask FixBot
    2. Steam Machine (2026) SSD Replacement, Remove the feet: step 3, image 1 of 3 Steam Machine (2026) SSD Replacement, Remove the feet: step 3, image 2 of 3 Steam Machine (2026) SSD Replacement, Remove the feet: step 3, image 3 of 3
      • Use a T8 Torx screwdriver to remove the four rubber feet.
      Ask FixBot
    1. Steam Machine (2026) SSD Replacement, Reposition the Steam Machine: step 4, image 1 of 1
      • Reposition the Steam Machine so the back panel is facing up.
      Ask FixBot
    2. Steam Machine (2026) SSD Replacement, Loosen the back panel screws: step 5, image 1 of 2 Steam Machine (2026) SSD Replacement, Loosen the back panel screws: step 5, image 2 of 2
      • Use a T8 Torx screwdriver to fully loosen the two captive screws securing the back panel.
      Ask FixBot
    3. Steam Machine (2026) SSD Replacement, Remove the back panel: step 6, image 1 of 3 Steam Machine (2026) SSD Replacement, Remove the back panel: step 6, image 2 of 3 Steam Machine (2026) SSD Replacement, Remove the back panel: step 6, image 3 of 3
      • The back panel is secured by two hinge clips near the bottom corners and two locking clips on the sides.
      • Lift the top edge of the panel (near the screws) until the two locking clips release.
      • If you're having trouble getting an initial grip on the panel, use a spudger to lift it enough to grab with your fingers.
      • Slide the panel towards the top edge and lift to remove it.
      Ask FixBot
    4. Steam Machine (2026) SSD Replacement, Remove the inner assembly screws: step 7, image 1 of 2 Steam Machine (2026) SSD Replacement, Remove the inner assembly screws: step 7, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the inner assembly.
      Ask FixBot
    5. Steam Machine (2026) SSD Replacement, Remove the inner assembly: step 8, image 1 of 3 Steam Machine (2026) SSD Replacement, Remove the inner assembly: step 8, image 2 of 3 Steam Machine (2026) SSD Replacement, Remove the inner assembly: step 8, image 3 of 3
      • After removal, don't lay the inner assembly down on the microSD and USB ports. These ports are fragile and shouldn't have the weight of the assembly resting on them.
      • Grip the inner assembly under the fan and lift it straight up and out of the shell.
      • Set the inner assembly down so the SSD is on top.
      Ask FixBot
    1. Steam Machine (2026) SSD Replacement, Remove the SSD screw: step 9, image 1 of 2 Steam Machine (2026) SSD Replacement, Remove the SSD screw: step 9, image 2 of 2
      • Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the SSD.
      • With the screw removed, the SSD will pop up at a shallow angle.
      Ask FixBot
    2. Steam Machine (2026) SSD Replacement, Remove the SSD: step 10, image 1 of 2 Steam Machine (2026) SSD Replacement, Remove the SSD: step 10, image 2 of 2
      • Don't pull up on the SSD at a sharp angle, or you may damage the SSD and its socket.
      • Pull the SSD out of its socket at the angle it popped up at to remove it.
      Ask FixBot
    3. Steam Machine (2026) SSD Replacement, If changing SSD length: step 11, image 1 of 2 Steam Machine (2026) SSD Replacement, If changing SSD length: step 11, image 2 of 2
      • The standoff screw can be moved to accommodate two different SSD form factors: 2280 or 2230.
      • Use a 5.0 mm nut driver to remove the standoff screw and install it in the desired position:
      • 2280
      • 2230
      Ask FixBot
2 other people completed this guide.
Author
with
Spencer Day
210,776 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 276
Past 7 Days: 1,944
Past 30 Days: 5,007
All Time: 8,900
