OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Tools
Spudger4.9
Introduction
Go to step 1 ↓Follow this guide to replace the SSD board in your Valve Steam Machine (2026).
The Steam Machine relocates the SSD's M.2 connector onto a breakout board for easier access.
If your Steam Machine experiences storage failures, fails to detect the SSD, has corrupted storage, or keeps crashing, there's a chance you may need to replace the SSD board.
Power down your Steam Machine and disconnect the power cable.
Unplug any remaining cables or accessories from all ports.
Reposition the Steam Machine so the back panel is facing up.
Use a T8 Torx screwdriver to fully loosen the two captive screws securing the back panel.
Lift the top edge of the panel (near the screws) until the two locking clips release.
Slide the panel towards the top edge and lift to remove it.
Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the inner assembly.
Grip the inner assembly under the fan and lift it straight up and out of the shell.
Set the inner assembly down so the SSD is on top.
Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the SSD.
Pull the SSD out of its socket at the angle it popped up at to remove it.
Use a 5.0Â mm nut driver to remove the standoff screw and install it in the desired position:
2280
2230
Use a T8 Torx screwdriver to remove the two 5.1 mm‑long screws securing the SSD board and its cover.
With one hand, hold the board down by the SSD socket.
With your free hand, use the flat end of a spudger to pry up and disconnect the board's press connector.
