OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Tools
Spudger4.9
Introduction
Go to step 1 ↓Follow this guide to replace the front USB and power button board in your Valve Steam Machine (2026).
The front board includes two USB-A ports as well as the power button, which are all soldered to the board. To replace any one of these ports, it's easiest to replace the entire board.
If the front ports in your Steam Machine are loose or won't connect, you may need to replace the board. Replacing the front board can also fix issues with the power button sticking or not working.
Before starting this repair, clean the ports out first and test them with different cables to confirm the problem is with the ports themselves.
Power down your Steam Machine and disconnect the power cable.
Unplug any remaining cables or accessories from all ports.
Reposition the Steam Machine so the back panel is facing up.
Use a T8 Torx screwdriver to fully loosen the two captive screws securing the back panel.
Lift the top edge of the panel (near the screws) until the two locking clips release.
Slide the panel towards the top edge and lift to remove it.
Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the inner assembly.
Grip the inner assembly under the fan and lift it straight up and out of the shell.
Set the inner assembly down so the SSD is on top.
Use a T8 Torx screwdriver to remove the two 5.1 mm‑long screws securing the microSD card reader.
Pull the microSD card reader straight up to disconnect and remove it.
Reposition the inner assembly so the fan is on the bottom and the two USB ports are closest to you.
Use a T8 Torx screwdriver to remove the two 5.1 mm‑long screws securing the front port cable cover.
Use the flat end of a spudger to pry up and disconnect the board's press connector.
Use the point of a spudger to lift and disconnect the three coaxial connectors, making sure to lift as close to the connector head as possible.
Use a T8 Torx screwdriver to remove the three 5.1 mm‑long screws securing the front port board.
The light guide is secured with plugs that go through the board.
Pull up the light guide and remove it, being careful not to rip off any of the plugs.
Align the light guide over your replacement board and slowly pull each plug through the hole, letting it stretch until it can slide through.
