Up to 20% off select tools
Steam Machine (2026) Front Port Cover Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
109
All Time:
395
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Tools
Introduction
Go to step 1 ↓
Follow this guide to remove or replace the front port cover on your Valve Steam Machine (2026).
    1. Steam Machine (2026) Front Port Cover Replacement, Before you begin: step 1, image 1 of 3 Steam Machine (2026) Front Port Cover Replacement, Before you begin: step 1, image 2 of 3 Steam Machine (2026) Front Port Cover Replacement, Before you begin: step 1, image 3 of 3
      • Before you begin this repair:
      • Power down your Steam Machine and disconnect the power cable.
      • Unplug any remaining cables or accessories from all ports.
      • If you have a microSD card installed, remove it. Otherwise, it may break during this procedure.
      Ask FixBot
    1. Steam Machine (2026) Front Port Cover Replacement, Reposition the Steam Machine: step 2, image 1 of 1
      • Reposition the Steam Machine so the bottom is facing up.
      Ask FixBot
    2. Steam Machine (2026) Front Port Cover Replacement, Remove the feet: step 3, image 1 of 3 Steam Machine (2026) Front Port Cover Replacement, Remove the feet: step 3, image 2 of 3 Steam Machine (2026) Front Port Cover Replacement, Remove the feet: step 3, image 3 of 3
      • Use a T8 Torx screwdriver to remove the four rubber feet.
      Ask FixBot
    1. Steam Machine (2026) Front Port Cover Replacement, Reposition the Steam Machine: step 4, image 1 of 1
      • Reposition the Steam Machine so the back panel is facing up.
      Ask FixBot
    2. Steam Machine (2026) Front Port Cover Replacement, Loosen the back panel screws: step 5, image 1 of 2 Steam Machine (2026) Front Port Cover Replacement, Loosen the back panel screws: step 5, image 2 of 2
      • Use a T8 Torx screwdriver to fully loosen the two captive screws securing the back panel.
      Ask FixBot
    3. Steam Machine (2026) Front Port Cover Replacement, Remove the back panel: step 6, image 1 of 3 Steam Machine (2026) Front Port Cover Replacement, Remove the back panel: step 6, image 2 of 3 Steam Machine (2026) Front Port Cover Replacement, Remove the back panel: step 6, image 3 of 3
      • The back panel is secured by two hinge clips near the bottom corners and two locking clips on the sides.
      • Lift the top edge of the panel (near the screws) until the two locking clips release.
      • If you're having trouble getting an initial grip on the panel, use a spudger to lift it enough to grab with your fingers.
      • Slide the panel towards the top edge and lift to remove it.
      Ask FixBot
    4. Steam Machine (2026) Front Port Cover Replacement, Remove the inner assembly screws: step 7, image 1 of 2 Steam Machine (2026) Front Port Cover Replacement, Remove the inner assembly screws: step 7, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the inner assembly.
      Ask FixBot
    5. Steam Machine (2026) Front Port Cover Replacement, Remove the inner assembly: step 8, image 1 of 3 Steam Machine (2026) Front Port Cover Replacement, Remove the inner assembly: step 8, image 2 of 3 Steam Machine (2026) Front Port Cover Replacement, Remove the inner assembly: step 8, image 3 of 3
      • After removal, don't lay the inner assembly down on the microSD and USB ports. These ports are fragile and shouldn't have the weight of the assembly resting on them.
      • Grip the inner assembly under the fan and lift it straight up and out of the shell.
      • Set the inner assembly down so the SSD is on top.
      Ask FixBot
    1. Steam Machine (2026) Front Port Cover Replacement, Remove the front port cover screws: step 9, image 1 of 2 Steam Machine (2026) Front Port Cover Replacement, Remove the front port cover screws: step 9, image 2 of 2
      • Use a T8 Torx screwdriver to remove the three 5.1 mm‑long screws securing the front port cover.
      Ask FixBot
    2. Steam Machine (2026) Front Port Cover Replacement, Reposition the shell: step 10, image 1 of 1
      • Reposition the shell so the open side is facing you.
      • This allows the front port cover to unclip in the next step.
      Ask FixBot
    3. Steam Machine (2026) Front Port Cover Replacement, Unclip the front port cover: step 11, image 1 of 3 Steam Machine (2026) Front Port Cover Replacement, Unclip the front port cover: step 11, image 2 of 3 Steam Machine (2026) Front Port Cover Replacement, Unclip the front port cover: step 11, image 3 of 3
      • Two plastic clips secure the front port cover to the shell.
      • Use your finger to push both clips in to release them.
      Ask FixBot
    4. Steam Machine (2026) Front Port Cover Replacement, Remove the front port cover: step 12, image 1 of 1
      • Remove the front port cover.
      Ask FixBot
Author
with
Spencer Day
210,776 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 109
All Time: 395
