Up to 20% off select tools
Steam Machine (2026) Fan Replacement
View statistics:
Past 24 Hours:
10
Past 7 Days:
45
Past 30 Days:
214
All Time:
829
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the fan in your Valve Steam Machine (2026).
If the fan in your Steam Machine stops spinning or starts making weird noises, it might need replacement.
Before starting this repair, follow our Steam Machine cleaning guide and see if it fixes your issue. Something as simple as a buildup of dust and grime can be misdiagnosed as a failing fan.
While overheating can be a symptom of a failing fan, it's often a result of old thermal paste. If you suspect this is the case, follow our motherboard guide for instructions on how to remove and reapply thermal material.
    1. Steam Machine (2026) Fan Replacement, Before you begin: step 1, image 1 of 3 Steam Machine (2026) Fan Replacement, Before you begin: step 1, image 2 of 3 Steam Machine (2026) Fan Replacement, Before you begin: step 1, image 3 of 3
      • Before you begin this repair:
      • Power down your Steam Machine and disconnect the power cable.
      • Unplug any remaining cables or accessories from all ports.
      • If you have a microSD card installed, remove it. Otherwise, it may break during this procedure.
      Ask FixBot
    1. Steam Machine (2026) Fan Replacement, Reposition the Steam Machine: step 2, image 1 of 1
      • Reposition the Steam Machine so the bottom is facing up.
      Ask FixBot
    2. Steam Machine (2026) Fan Replacement, Remove the feet: step 3, image 1 of 3 Steam Machine (2026) Fan Replacement, Remove the feet: step 3, image 2 of 3 Steam Machine (2026) Fan Replacement, Remove the feet: step 3, image 3 of 3
      • Use a T8 Torx screwdriver to remove the four rubber feet.
      Ask FixBot
    1. Steam Machine (2026) Fan Replacement, Reposition the Steam Machine: step 4, image 1 of 1
      • Reposition the Steam Machine so the back panel is facing up.
      Ask FixBot
    2. Steam Machine (2026) Fan Replacement, Loosen the back panel screws: step 5, image 1 of 2 Steam Machine (2026) Fan Replacement, Loosen the back panel screws: step 5, image 2 of 2
      • Use a T8 Torx screwdriver to fully loosen the two captive screws securing the back panel.
      Ask FixBot
    3. Steam Machine (2026) Fan Replacement, Remove the back panel: step 6, image 1 of 3 Steam Machine (2026) Fan Replacement, Remove the back panel: step 6, image 2 of 3 Steam Machine (2026) Fan Replacement, Remove the back panel: step 6, image 3 of 3
      • The back panel is secured by two hinge clips near the bottom corners and two locking clips on the sides.
      • Lift the top edge of the panel (near the screws) until the two locking clips release.
      • If you're having trouble getting an initial grip on the panel, use a spudger to lift it enough to grab with your fingers.
      • Slide the panel towards the top edge and lift to remove it.
      Ask FixBot
    4. Steam Machine (2026) Fan Replacement, Remove the inner assembly screws: step 7, image 1 of 2 Steam Machine (2026) Fan Replacement, Remove the inner assembly screws: step 7, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the inner assembly.
      Ask FixBot
    5. Steam Machine (2026) Fan Replacement, Remove the inner assembly: step 8, image 1 of 3 Steam Machine (2026) Fan Replacement, Remove the inner assembly: step 8, image 2 of 3 Steam Machine (2026) Fan Replacement, Remove the inner assembly: step 8, image 3 of 3
      • After removal, don't lay the inner assembly down on the microSD and USB ports. These ports are fragile and shouldn't have the weight of the assembly resting on them.
      • Grip the inner assembly under the fan and lift it straight up and out of the shell.
      • Set the inner assembly down so the SSD is on top.
      Ask FixBot
    1. Steam Machine (2026) Fan Replacement, Reposition the inner assembly: step 9, image 1 of 1
      • Spin the inner assembly so the fan faces you.
      Ask FixBot
    2. Steam Machine (2026) Fan Replacement, Remove the cable cover screws: step 10, image 1 of 2 Steam Machine (2026) Fan Replacement, Remove the cable cover screws: step 10, image 2 of 2
      • Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the rear USB and Ethernet port cable cover.
      Ask FixBot
    3. Steam Machine (2026) Fan Replacement, Remove the cable cover: step 11, image 1 of 2 Steam Machine (2026) Fan Replacement, Remove the cable cover: step 11, image 2 of 2
      • Remove the cable cover.
      • During reassembly, make sure the tab on the edge of the cable cover slides into its cutout in the fan.
      Ask FixBot
    4. Steam Machine (2026) Fan Replacement, Disconnect the board: step 12, image 1 of 2 Steam Machine (2026) Fan Replacement, Disconnect the board: step 12, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the board's press connector.
      Ask FixBot
    5. Steam Machine (2026) Fan Replacement, Remove the board screw: step 13, image 1 of 2 Steam Machine (2026) Fan Replacement, Remove the board screw: step 13, image 2 of 2
      • Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the rear USB and Ethernet port board.
      Ask FixBot
    6. Steam Machine (2026) Fan Replacement, Remove the board: step 14, image 1 of 2 Steam Machine (2026) Fan Replacement, Remove the board: step 14, image 2 of 2
      • Slide the board straight away fron the inner assembly to remove it.
      Ask FixBot
    1. Steam Machine (2026) Fan Replacement, Reposition the inner assembly: step 15, image 1 of 2 Steam Machine (2026) Fan Replacement, Reposition the inner assembly: step 15, image 2 of 2
      • Reposition the inner assembly so the antenna marked AUX ANT is facing up.
      Ask FixBot
    2. Steam Machine (2026) Fan Replacement, Heat the auxiliary antenna: step 16, image 1 of 3 Steam Machine (2026) Fan Replacement, Heat the auxiliary antenna: step 16, image 2 of 3 Steam Machine (2026) Fan Replacement, Heat the auxiliary antenna: step 16, image 3 of 3
      • Mild adhesive secures the auxiliary antenna to the fan. Heating the antenna softens the adhesive, making it easier to separate. If you don't want to remove the antennas from the fan, you can disconnect and de-route them.
      • Lay a heated iOpener on the auxiliary antenna for two minutes.
      • Check out this guide for instruction on heating an iOpener.
      • Alternatively, you can use a hair dryer to soften the adhesive. For tips on using a hair dryer without accidentally melting plastic, check out this guide.
      Ask FixBot
    3. Steam Machine (2026) Fan Replacement, Separate the auxiliary antenna: step 17, image 1 of 3 Steam Machine (2026) Fan Replacement, Separate the auxiliary antenna: step 17, image 2 of 3 Steam Machine (2026) Fan Replacement, Separate the auxiliary antenna: step 17, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Slide the flat end of a spudger under the antenna and lift to separate the adhesive.
      • During reassembly, the adhesive should be sticky enough to reuse. If it isn't, use thin double-sided tape to secure the antenna.
      Ask FixBot
    4. Steam Machine (2026) Fan Replacement, De-route the auxiliary antenna: step 18, image 1 of 3 Steam Machine (2026) Fan Replacement, De-route the auxiliary antenna: step 18, image 2 of 3 Steam Machine (2026) Fan Replacement, De-route the auxiliary antenna: step 18, image 3 of 3
      • Guide the antenna cable out of its clips on the fan.
      Ask FixBot
    5. Steam Machine (2026) Fan Replacement, Reposition the inner assembly: step 19, image 1 of 2 Steam Machine (2026) Fan Replacement, Reposition the inner assembly: step 19, image 2 of 2
      • Reposition the inner assembly so the antenna marked MAIN ANT is facing up.
      Ask FixBot
    6. Steam Machine (2026) Fan Replacement, Heat the main antenna: step 20, image 1 of 3 Steam Machine (2026) Fan Replacement, Heat the main antenna: step 20, image 2 of 3 Steam Machine (2026) Fan Replacement, Heat the main antenna: step 20, image 3 of 3
      • Mild adhesive secures the main antenna to the fan. Heating the antenna softens the adhesive, making it easier to separate.
      • Lay a heated iOpener on the main antenna for two minutes.
      Ask FixBot
    7. Steam Machine (2026) Fan Replacement, Separate the main antenna: step 21, image 1 of 3 Steam Machine (2026) Fan Replacement, Separate the main antenna: step 21, image 2 of 3 Steam Machine (2026) Fan Replacement, Separate the main antenna: step 21, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      Ask FixBot
    8. Steam Machine (2026) Fan Replacement, De-route the main antenna: step 22, image 1 of 3 Steam Machine (2026) Fan Replacement, De-route the main antenna: step 22, image 2 of 3 Steam Machine (2026) Fan Replacement, De-route the main antenna: step 22, image 3 of 3
      • Guide the antenna cable out of its plastic clips.
      Ask FixBot
    9. Steam Machine (2026) Fan Replacement, Disconnect the fan: step 23, image 1 of 3 Steam Machine (2026) Fan Replacement, Disconnect the fan: step 23, image 2 of 3 Steam Machine (2026) Fan Replacement, Disconnect the fan: step 23, image 3 of 3
      • The fan connector can be tricky to disconnect. Be careful: excessive force could rip the socket off the board.
      • Use a pair of angled tweezers to firmly grip the head of the fan cable connector.
      • To get the best grip, hold the tweezers close to the pointed ends.
      • Gently rock the connector side-to-side while lifting to disconnect it.
      Ask FixBot
    10. Steam Machine (2026) Fan Replacement, Peel up the fan cable: step 24, image 1 of 2 Steam Machine (2026) Fan Replacement, Peel up the fan cable: step 24, image 2 of 2
      • Peel up the tape securing the fan cable to the heatsink.
      Ask FixBot
    11. Steam Machine (2026) Fan Replacement, Reposition the inner assembly: step 25, image 1 of 1
      • Reposition the inner assembly so the fan is facing you and the power cable socket is on the bottom.
      Ask FixBot
    12. Steam Machine (2026) Fan Replacement, Remove the fan screws: step 26, image 1 of 2 Steam Machine (2026) Fan Replacement, Remove the fan screws: step 26, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the fan.
      Ask FixBot
    13. Steam Machine (2026) Fan Replacement, Remove the fan: step 27, image 1 of 2 Steam Machine (2026) Fan Replacement, Remove the fan: step 27, image 2 of 2
      • Slide the fan straight away from the inner assembly to remove it.
      • During reassembly, make sure no cables get stuck behind the fan when sliding it back in place.
      Ask FixBot
When putting your Steam Machine back where it lives, make sure it's in an area with at least a few inches of space on all sides. If your console sits in an entertainment center, make sure at least one panel is open to provide airflow. Avoid keeping the console on carpet or other similar surfaces, as your device is more likely to suck up dirt, dust, and hair.
Author
with
Spencer Day
210,776 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 45
Past 30 Days: 214
All Time: 829
