Up to 20% off select tools
Steam Link Disassembly
Views: 8.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
38
Past 30 Days:
160
All Time:
8,763
Comments: 4
4 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the disassembly of the Steam Link device made by Valve from 2015 to 2018
    1. Steam Link Disassembly, Starting up: step 1, image 1 of 2 Steam Link Disassembly, Starting up: step 1, image 2 of 2
      • Start by unplugging your device
      • Power cord
      • Ethernet
      • HDMI
      Ask FixBot
    2. Steam Link Disassembly, Removing the rubber bottom: step 2, image 1 of 2 Steam Link Disassembly, Removing the rubber bottom: step 2, image 2 of 2
      • Start by removing the rubber bottom using the Guitar Pick or the Jimmy
      • The first time, the adhesive may be difficult to remove
      Ask FixBot
    3. Steam Link Disassembly, Removing the screws: step 3, image 1 of 2 Steam Link Disassembly, Removing the screws: step 3, image 2 of 2
      • Remove the screws using a Torxx 6 bit
      Ask FixBot
    4. Steam Link Disassembly, Opening the lid: step 4, image 1 of 2 Steam Link Disassembly, Opening the lid: step 4, image 2 of 2
      • Open-up the bottom lid using guitar pics
      • The first time you open it, it might be difficult to open. Start by reaching the rounded, bottom-right corner
      Ask FixBot
    5. Steam Link Disassembly, Main board inspection: step 5, image 1 of 2 Steam Link Disassembly, Main board inspection: step 5, image 2 of 2
      • Marvel ArmV7 CPU
      • Vivante GC1000 GPU
      Ask FixBot
To reassemble your device, follow the steps in the opposite order
11 other people completed this guide.
Author
with
Jorys Paulin (Jorys_Paulin)
479 Reputation
1 Guide authored
4 Guide Comments
bonjour esque cette carte peu servire comme raspberry merci
thesmoking gta - Reply Share
Non, seule une image signée par Valve peut être lancée. Elle a un accès SSH comme indiqué sur la page du SDK cependant. Notez qu'elle n'est plus fabriquée depuis décembre, donc elle n'est plus vraiment disponible.
Jorys Paulin (Jorys_Paulin) - Reply Share
Somewhat unworthy Teardown. Naming the CPU brand wrong and not giving any relevant information like schematics or ICs used. THIS is by far better: https://www.allaboutcircuits.com/news/te...
EDIT: Oh, it is a community post, sry. But more information would be nice. E.g. where is the massive heat sink? There are lots of parts missing.
Jan Seewald - Reply Share
Hello, this is my first (and only) teardown. I made it just for fun, really. I opened my Steam Link once and then decided to put it on the internet, because I found they weren’t that much photos of it around.
The heat sink is a large piece of aluminum, and now I realize I forgot to add it, my mistake.
Past 24 Hours: 3
Past 7 Days: 38
Past 30 Days: 160
All Time: 8,763
