Steam Deck Motherboard Replacement
    1. Steam Deck Motherboard Replacement, Prepare your Steam Deck for disassembly: step 1, image 1 of 3 Steam Deck Motherboard Replacement, Prepare your Steam Deck for disassembly: step 1, image 2 of 3 Steam Deck Motherboard Replacement, Prepare your Steam Deck for disassembly: step 1, image 3 of 3
      • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
      • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
      • Power down your Steam Deck and unplug any cables.
      • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
      • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
      Ask FixBot
    2. Steam Deck Motherboard Replacement, Remove the back cover screws: step 2, image 1 of 1
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a Phillips driver to remove the eight screws securing the back cover:
      • Four coarse thread 9.5 mm-long screws
      • Four fine thread 5.8 mm-long screws
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
      Ask FixBot
    3. Steam Deck Motherboard Replacement, Unclip the back cover: step 3, image 1 of 2 Steam Deck Motherboard Replacement, Unclip the back cover: step 3, image 2 of 2
      • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
      • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
      • Pry up on the back cover to release it from the locking clips.
      Ask FixBot
    4. Steam Deck Motherboard Replacement, Remove the back cover: step 4, image 1 of 3 Steam Deck Motherboard Replacement, Remove the back cover: step 4, image 2 of 3 Steam Deck Motherboard Replacement, Remove the back cover: step 4, image 3 of 3
      • Once the clips are disconnected from one edge, the rest disconnect easily.
      • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
      • Remove the back cover.
      Ask FixBot
    1. Steam Deck Motherboard Replacement, Uncover the hidden shield screw: step 5, image 1 of 2 Steam Deck Motherboard Replacement, Uncover the hidden shield screw: step 5, image 2 of 2
      Buy
      • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
      • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
      • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
      Ask FixBot
    2. Steam Deck Motherboard Replacement, Remove the shield screws: step 6, image 1 of 2 Steam Deck Motherboard Replacement, Remove the shield screws: step 6, image 2 of 2
      • Use a Phillips driver to remove the three screws securing the board shield:
      • One 3.4 mm screw
      • Two 3.7 mm screws
      • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
      Ask FixBot
    3. Steam Deck Motherboard Replacement, Remove the shield: step 7, image 1 of 3 Steam Deck Motherboard Replacement, Remove the shield: step 7, image 2 of 3 Steam Deck Motherboard Replacement, Remove the shield: step 7, image 3 of 3
      • Remove the board shield.
      • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
      • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
      Ask FixBot
    4. Steam Deck Motherboard Replacement, Disconnect the battery: step 8, image 1 of 3 Steam Deck Motherboard Replacement, Disconnect the battery: step 8, image 2 of 3 Steam Deck Motherboard Replacement, Disconnect the battery: step 8, image 3 of 3
      • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
      • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
      Ask FixBot
    1. Steam Deck Motherboard Replacement, Remove the SSD screw: step 9, image 1 of 1
      • Use a Phillips driver to remove the 3.4 mm screw securing the SSD.
      Ask FixBot
    2. Steam Deck Motherboard Replacement, Remove the SSD: step 10, image 1 of 2 Steam Deck Motherboard Replacement, Remove the SSD: step 10, image 2 of 2
      • With the SSD screw removed, the SSD will pop up at a shallow angle.
      • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
      • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
      Ask FixBot
    1. Steam Deck Motherboard Replacement, Remove the heatsink sticker: step 11, image 1 of 3 Steam Deck Motherboard Replacement, Remove the heatsink sticker: step 11, image 2 of 3 Steam Deck Motherboard Replacement, Remove the heatsink sticker: step 11, image 3 of 3
      Buy
      • Use a pair of tweezers to remove the sticker from the top edge of the fan.
      • If possible, try not to rip or tear this sticker so it can be reused. Use a little bit of heat if necessary to soften the adhesive.
      • If the sticker feels like it might tear, use tweezers to peel up one edge just until you can grip it with your fingers, then remove the rest by hand.
      Ask FixBot
    1. Steam Deck Motherboard Replacement, Remove the heatsink screws: step 12, image 1 of 2 Steam Deck Motherboard Replacement, Remove the heatsink screws: step 12, image 2 of 2
      • For original Steam Decks: Use a Phillips driver to loosen and remove the two screws securing the heatsink to the motherboard:
      • One captive 3.5 mm screw
      • One 3.4 mm screw
      • No, your eyes don't deceive you! The third heatsink screw was removed earlier in the disassembly: it doubles as the hidden board shield screw.
      • For refreshed Steam Decks: Use a Phillips driver to remove the three screws securing the heatsink to the motherboard:
      • Two 2.9 mm screws
      • One 3.7 mm screw
      • During reassembly on both versions, tighten these screws in order (1, 2, 3) as stamped into the heatsink.
      Ask FixBot
    2. Steam Deck Motherboard Replacement, Remove the heatsink: step 13, image 1 of 3 Steam Deck Motherboard Replacement, Remove the heatsink: step 13, image 2 of 3 Steam Deck Motherboard Replacement, Remove the heatsink: step 13, image 3 of 3
      • Lift and remove the heatsink.
      • Before reinstalling the heatsink, follow this guide to clean the heatsink and APU and reapply thermal paste.
      Ask FixBot
    1. Steam Deck Motherboard Replacement, Disconnect the fan: step 14, image 1 of 2 Steam Deck Motherboard Replacement, Disconnect the fan: step 14, image 2 of 2
      Buy
      • Use a pair of tweezers to grip the edges of the fan connector and pull up to disconnect it from the motherboard.
      • Pull the fan cable by its connector, not the wires themselves.
      Ask FixBot
    2. Steam Deck Motherboard Replacement, Remove the Wi-Fi shield tape: step 15, image 1 of 3 Steam Deck Motherboard Replacement, Remove the Wi-Fi shield tape: step 15, image 2 of 3 Steam Deck Motherboard Replacement, Remove the Wi-Fi shield tape: step 15, image 3 of 3
      • Use a pair of tweezers to peel up and remove the Wi-Fi shield tape.
      Ask FixBot
    3. Steam Deck Motherboard Replacement, Disconnect the speakers: step 16, image 1 of 2 Steam Deck Motherboard Replacement, Disconnect the speakers: step 16, image 2 of 2
      • Use a pair of tweezers to grip the edges of the speaker connector and pull up to disconnect it from the motherboard.
      • Pull the speaker cable by its connector, not the wires themselves.
      Ask FixBot
    4. Steam Deck Motherboard Replacement, Disconnect the Wi-Fi: step 17, image 1 of 3 Steam Deck Motherboard Replacement, Disconnect the Wi-Fi: step 17, image 2 of 3 Steam Deck Motherboard Replacement, Disconnect the Wi-Fi: step 17, image 3 of 3
      • The Wi-Fi module is located next to the SSD on refreshed Steam Decks.
      • Use a pair of tweezers to grip the antenna connector close to its base.
      • Pull straight up to disconnect the cable.
      • Repeat for the second antenna cable.
      • During reassembly, ensure that both antenna cables are reconnected at their appropriate connectors. The labels on the cables match the markings on the Wi-Fi module.
      • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
      Ask FixBot
    5. Steam Deck Motherboard Replacement, Disconnect the display: step 18, image 1 of 3 Steam Deck Motherboard Replacement, Disconnect the display: step 18, image 2 of 3 Steam Deck Motherboard Replacement, Disconnect the display: step 18, image 3 of 3
      • Use the pointed end of a spudger to lift up the small locking flap on the display cable's ZIF connector.
      • Use a pair of tweezers to slide the cable out of its connector.
      • Grip the cable by the pull tab, not by the cable itself.
      Ask FixBot
    6. Steam Deck Motherboard Replacement, Disconnect the audio cable: step 19, image 1 of 2 Steam Deck Motherboard Replacement, Disconnect the audio cable: step 19, image 2 of 2
      • Refreshed Steam Decks don't have this audio cable. If you have a refreshed version, skip the next three steps.
      • Use the pointed end of a spudger to lift up the small locking flap on the audio cable's ZIF connector.
      Ask FixBot
    7. Steam Deck Motherboard Replacement: step 20, image 1 of 2 Steam Deck Motherboard Replacement: step 20, image 2 of 2
      • Grip the cable by its pull tab, not by the cable itself.
      Ask FixBot
    8. Steam Deck Motherboard Replacement: step 21, image 1 of 3 Steam Deck Motherboard Replacement: step 21, image 2 of 3 Steam Deck Motherboard Replacement: step 21, image 3 of 3
      • Carefully peel the audio cable off of the battery.
      • The audio cable is secured to the battery with some light adhesive.
      • If the adhesive is stubborn, don't force the cable. Lightly heat the audio cable using an iOpener or a hair dryer to soften the adhesive.
      Ask FixBot
    9. Steam Deck Motherboard Replacement, Disconnect the button board: step 22, image 1 of 3 Steam Deck Motherboard Replacement, Disconnect the button board: step 22, image 2 of 3 Steam Deck Motherboard Replacement, Disconnect the button board: step 22, image 3 of 3
      • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
      • Grip the cable by the blue pull tab, not by the cable itself.
      Ask FixBot
    10. Steam Deck Motherboard Replacement, Remove the motherboard screws: step 23, image 1 of 1
      • Use a Phillips driver to remove the three 3.7 mm screws securing the motherboard.
      Ask FixBot
    11. Steam Deck Motherboard Replacement, Remove the motherboard: step 24, image 1 of 3 Steam Deck Motherboard Replacement, Remove the motherboard: step 24, image 2 of 3 Steam Deck Motherboard Replacement, Remove the motherboard: step 24, image 3 of 3
      • Remove the motherboard.
      • The audio and button board cables attach to the underside of the motherboard with ZIF connectors.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
12 other people completed this guide.
Carsten Frauenheim
171,545 Reputation
441 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
18 Guide Comments
When will I be able to buy the motherboard?
Jing - Reply Share
I would love the answer to this question as well. This is necessary!
SpectralFox - Reply Share
What is the actual size of the screws (M1.6, M2 , M2.2) as this information would be helpful if someone was to lose a screw while carrying out a repair or re paste.
Luis Elias castro - Reply Share
Why Can't I buy this accessory?
ziyang - Reply Share
Could we change dram or apu on the motherboard or upgrade thé motherboard ? Cause it s just zen2 and rdn2 .we need better performance and power !!!!
lapartdesanges50 - Reply Share
Past 24 Hours: 47
Past 7 Days: 303
Past 30 Days: 1,444
All Time: 103,110
