Steam Controller (2nd Gen, 2026) Left Trackpad Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
34
Past 30 Days:
125
All Time:
1,210
Comments: 8
6 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to replace the left trackpad (aka touchpad) in your Steam Controller (2nd Gen, 2026).
If your trackpad is sticking, damaged, isn't registering, or has inconsistent inputs, you may need to replace it.
Tools
    1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Before you begin: step 1, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Before you begin: step 1, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Before you begin: step 1, image 3 of 3
      • Let your controller's battery drain below 25% before starting this repair.
      • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
      • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
      Ask FixBot
    2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the back cover screws: step 2, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the back cover screws: step 2, image 2 of 2
      Tool used on this step:
      TR6 Torx Security Screwdriver
      $5.99
      Buy
      Ask FixBot
    3. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the back cover: step 3, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the back cover: step 3, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the battery: step 4, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the battery: step 4, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the battery: step 4, image 3 of 3
      • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
      • Lift the right edge of the battery to remove it.
      • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
      Ask FixBot
    1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the mounting bracket screws: step 5, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the mounting bracket screws: step 5, image 2 of 2
      • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
      • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
      Ask FixBot
    2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the mounting bracket: step 6, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the mounting bracket: step 6, image 2 of 2
      Ask FixBot
    1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the rumble motors: step 7, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the rumble motors: step 7, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the rumble motors: step 7, image 3 of 3
      • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
      • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
      • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
      Ask FixBot
    2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 8, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 8, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 8, image 3 of 3
      • Repeat to disconnect the other rumble motor.
      Ask FixBot
    3. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the interconnect cable: step 9, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the interconnect cable: step 9, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the interconnect cable: step 9, image 3 of 3
      • Be careful not to damage any of the small, surface-mounted components on the main board.
      • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
      Ask FixBot
    4. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 10, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 10, image 2 of 2
      • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
      Ask FixBot
    5. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board screws: step 11, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board screws: step 11, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board screws: step 11, image 3 of 3
      • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
      • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
      Ask FixBot
    6. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board: step 12, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board: step 12, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board: step 12, image 3 of 3
      • Pull the main board down so the top corners clear the triggers.
      • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
      • Remove the main board, guiding the thumbsticks through their cutouts.
      • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
      Ask FixBot
    7. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Rubber piece information: step 13, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Rubber piece information: step 13, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Rubber piece information: step 13, image 3 of 3
      • The rubber piece above the status LED may have been dislodged when removing the main board.
      • If the rubber piece is out of place, remove it and set it aside.
      • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
      Ask FixBot
    1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the hinge pin: step 14, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the hinge pin: step 14, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the hinge pin: step 14, image 3 of 3
      • With one hand, fully depress one trigger.
      • Don't let go of the trigger, or it will eject and you may lose its spring.
      • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
      • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
      • When correctly inserted, the pin's end will be alinged with the white rectangle on the board (labeled PIN)—there should be no wobble.
      Ask FixBot
    2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trigger: step 15, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trigger: step 15, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trigger: step 15, image 3 of 3
      • Lift the trigger straight up and remove it.
      • Remove the spring and store it in a safe place for reassembly.
      • The spring will either stick to the trigger's magnet or stay on its post.
      Ask FixBot
    3. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the other trigger: step 16, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the other trigger: step 16, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the other trigger: step 16, image 3 of 3
      • Repeat to remove the other trigger.
      Ask FixBot
    4. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Reassembly information: step 17, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Reassembly information: step 17, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Reassembly information: step 17, image 3 of 3
      • During reassembly, follow this step to install the triggers.
      • Place one of the trigger springs over its post on the controller.
      • Put the trigger in place, making sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
      • Hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted.
      • If you're having trouble, make sure you're installing the trigger on the correct side.
      • Test the trigger to ensure the pin was properly installed.
      • Repeat to install the other trigger.
      Ask FixBot
    5. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe screws: step 18, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe screws: step 18, image 2 of 2
      • Use a T6 Torx screwdriver to remove the eleven 7.4 mm‑long screws securing the midframe.
      • When removing the screw in the center of the controller, be careful not to slip and damage the flexible button circuit.
      Ask FixBot
    6. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe: step 19, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe: step 19, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe: step 19, image 3 of 3
      • Lift the midframe straight up and remove it.
      • The buttons and their silicone membranes are now sitting loose in their recesses. Don't flip the front shell or the buttons will fall out. Optionally, remove the membranes and buttons and set them aside.
      • During reassembly:
      • If you removed the buttons and their membranes:
      • Make sure the rubber button dampeners (that surround the button recesses) are pushed down and fully seated against the shell.
      • Install the buttons and membranes, using the alignment tabs to orient each button in its recess. Each one is keyed for proper location and orientation.
      • Check the two large silicone button membranes to make sure they're aligned properly and fully seated—if they aren't, button presses may feel off or not register.
      • Use the alignment posts to ensure the midframe is in the right position.
      Ask FixBot
    7. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Check for the Steam button membrane: step 20, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Check for the Steam button membrane: step 20, image 2 of 2
      • Check if the Steam button's silicone membrane stuck to the button circuit on the midframe.
      • If it did, either put the membrane back in place or set it aside.
      Ask FixBot
    1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the trackpad cables: step 21, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the trackpad cables: step 21, image 2 of 2
      • Use the flat end of a spudger to lift the hinged, locking flap on one of the trackpad ZIF connectors.
      Ask FixBot
    2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 22, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 22, image 2 of 2
      Ask FixBot
    3. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 23, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 23, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: step 23, image 3 of 3
      • Repeat to disconnect the other trackpad cable.
      Ask FixBot
    4. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board screws: step 24, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board screws: step 24, image 2 of 2
      • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the FSC board.
      Ask FixBot
    5. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board: step 25, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board: step 25, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board: step 25, image 3 of 3
      • Remove the FSC board.
      • Use the alignment pegs to ensure the board is correctly positioned.
      Ask FixBot
    1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad screws: step 26, image 1 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad screws: step 26, image 2 of 3 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad screws: step 26, image 3 of 3
      • The left trackpad will be on your right-hand side, as the shell is upside down.
      • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the left trackpad.
      • When reinstalling the screws, raise the controller so the trackpad isn't pressed against your work surface. Don't lift too high, or the buttons may fall out.
      Ask FixBot
    2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad: step 27, image 1 of 2 Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad: step 27, image 2 of 2
      • Remove the trackpad.
      • During reassembly, set the trackpad into its cutout so the cable is on the bottom edge. Make sure all the alignment tabs and posts go through their cutouts by the screw holes.
      Ask FixBot
Spencer Day
207,384 Reputation
1,266 Guides authored
2 Guide Comments
I don’t own one, so I’d like to ask: ⏎
Does this touchpad have a mechanism that allows it to be physically pressed? ⏎
Also, do you know what kind of LRA is used for the haptic feedback?
Satoshi S - Reply Share
^ I also do not own one but I do have a Steam Deck with a broken touchpad. Out of curiousity, does this have the same crap as that, where the part needs "special calibration" or whatever and you can only find parts second hand that may work?
Tyler - Reply Share
Past 24 Hours: 2
Past 7 Days: 34
Past 30 Days: 125
All Time: 1,210
