OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Tools
Spudger4.9
Introduction
Go to step 1 ↓Follow this guide to replace, upgrade, or change the front shell (aka front cover, top shell, or top cover) on your Steam Controller (2nd Gen, 2026).
You may want to change the front shell for customization, a new color, or if it's cracked.
Unplug all cables and accessories from the controller, including the Steam Controller Puck.
Tool used on this step:TR6 Torx Security Screwdriver$5.99
Use a T6 Torx screwdriver to remove the seven screws securing the back cover.
Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from.
Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
Pull the main board down so the top corners clear the triggers.
Remove the main board, guiding the thumbsticks through their cutouts.
If the rubber piece is out of place, remove it and set it aside.
With one hand, hold one of the triggers down in the fully actuated position.
With your free hand, use tweezers to pull the hinge pin straight out and remove it.
Lift the trigger straight up and remove it.
Remove the spring and store it in a safe place for reassembly.
Place one of the trigger springs over its post on the controller.
Put the trigger in place, making sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
Hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted.
Test the trigger to ensure the pin was properly installed.
Repeat to install the other trigger.
Use a T6 Torx screwdriver to remove the eleven 7.4 mm‑long screws securing the midframe.
Lift the midframe straight up and remove it.
Check the two large silicone button pads to make sure they're aligned properly and fully seated—if they aren't, button presses may feel off or not register.
Use the alignment posts to ensure the midframe is in the right position.
Use the flat end of a spudger to lift the hinged, locking flap on one of the trackpad ZIF connectors.
Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the FSC board.
Remove the FSC board.
Use the alignment pegs to ensure the board is correctly positioned.
Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the left trackpad.
Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the right trackpad.
Remove the trackpad.
Make sure you're installing the correct trackpad in each recess. There's a small R and L notched into the trackpad and the shell, noting the correct side.
Set the trackpad into its cutout so the cable is on the bottom edge.
Make sure all the alignment tabs and posts go through their cutouts by the screw holes.
Use tweezers to remove the D‑Pad, View, Steam, Menu, ABXY, and Quick Access Menu buttons.
Use tweezers or a spudger to remove all the button dampeners (they surround the button recesses) from the front shell.
1 Guide Comment
Are the shell CADs available? Valve has released CAD files for the solid SC as well as its accompanying dongle; however, neither of the CADs help if you want to fully replace the shells.
