Steam Controller (2nd Gen, 2026) Battery Replacement
Views: 6.7K
View statistics:
Past 24 Hours:
26
Past 7 Days:
190
Past 30 Days:
714
All Time:
6,673
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to replace a dead or worn-out battery in your Steam Controller (2nd Gen, 2026).
The lithium-ion battery in your Steam Controller has a limited lifespan. If your controller doesn't hold a charge, dies unexpectedly, or only works when plugged in, the battery may need to be replaced.
If your battery is swollen, take appropriate precautions.
Tools
    1. Steam Controller (2nd Gen, 2026) Battery Replacement, Before you begin: step 1, image 1 of 3 Steam Controller (2nd Gen, 2026) Battery Replacement, Before you begin: step 1, image 2 of 3 Steam Controller (2nd Gen, 2026) Battery Replacement, Before you begin: step 1, image 3 of 3
      • Let your controller's battery drain below 25% before starting this repair.
      • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
      • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
      Ask FixBot
    2. Steam Controller (2nd Gen, 2026) Battery Replacement, Remove the back cover screws: step 2, image 1 of 2 Steam Controller (2nd Gen, 2026) Battery Replacement, Remove the back cover screws: step 2, image 2 of 2
      Tool used on this step:
      TR6 Torx Security Screwdriver
      $5.99
      Buy
      Ask FixBot
    3. Steam Controller (2nd Gen, 2026) Battery Replacement, Remove the back cover: step 3, image 1 of 2 Steam Controller (2nd Gen, 2026) Battery Replacement, Remove the back cover: step 3, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. Steam Controller (2nd Gen, 2026) Battery Replacement, Remove the battery: step 4, image 1 of 3 Steam Controller (2nd Gen, 2026) Battery Replacement, Remove the battery: step 4, image 2 of 3 Steam Controller (2nd Gen, 2026) Battery Replacement, Remove the battery: step 4, image 3 of 3
      • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
      • Lift the right edge of the battery to remove it.
      • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
      Ask FixBot
Calibrate your newly installed battery after completing this guide.
2 other people completed this guide.
Spencer Day
207,384 Reputation
1,266 Guides authored
1 Guide Comment
Where can I buy a replacement battery for Steam Controller (2nd Gen, 2026) ?
Bilbo Astrosmith - Reply Share
Past 24 Hours: 26
Past 7 Days: 190
Past 30 Days: 714
All Time: 6,673
