Steam Controller (2nd Gen, 2026) Back Cover Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
10
Past 7 Days:
85
Past 30 Days:
334
All Time:
3,939
Comments: 3
3 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to replace, upgrade, or change the back cover (aka back shell, bottom shell, or bottom cover) on your Steam Controller (2nd Gen, 2026).
You may want to change the back cover for customization, a new color, or if it's cracked.
Note: The L4, L5, R4, and R5 buttons are plastic-riveted to the back cover. In order to replace any of these buttons, you you must replace the back cover.
Tools
    1. Steam Controller (2nd Gen, 2026) Back Cover Replacement, Before you begin: step 1, image 1 of 3 Steam Controller (2nd Gen, 2026) Back Cover Replacement, Before you begin: step 1, image 2 of 3 Steam Controller (2nd Gen, 2026) Back Cover Replacement, Before you begin: step 1, image 3 of 3
      • Let your controller's battery drain below 25% before starting this repair.
      • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
      • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
      Ask FixBot
    2. Steam Controller (2nd Gen, 2026) Back Cover Replacement, Remove the back cover screws: step 2, image 1 of 2 Steam Controller (2nd Gen, 2026) Back Cover Replacement, Remove the back cover screws: step 2, image 2 of 2
      Tool used on this step:
      TR6 Torx Security Screwdriver
      $5.99
      Buy
      Ask FixBot
    3. Steam Controller (2nd Gen, 2026) Back Cover Replacement, Remove the back cover: step 3, image 1 of 2 Steam Controller (2nd Gen, 2026) Back Cover Replacement, Remove the back cover: step 3, image 2 of 2
      • Remove the back cover.
      Ask FixBot
Spencer Day
207,384 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 85
Past 30 Days: 334
All Time: 3,939
